camper4fun
Hi I'm having a problem getting my 2000 jetta to shut off without stalling it. I went to work last friday morning the car started fine got to work turned the key off and no way it wouldn't shut off. With the key off and out of the ignition it still ran but some lights were on in the dash ? I tried to locate a relay that would control the vehicle shutting off and only found relay 109 that would actually shut the vehicle off but the dash lights remain lite. I disconnected the battery and reconnected it with the keys out of ignition and I could hear the glow plugs come on then off and when I went back in the vehicle and tried to start it, it did start. If I let it sit for a short while with the battery still hooked up and the key out with the dash lights still lite and then try to start it no way will it start the glow plugs won't even light on the dash but the other lights on the dash stay lite. If I go out and take the battery cable off and put it right back on the car will start but will not shut off. Does anyone know what is happening here I'm really stuck on this one. Thank you for reading my post.
