jonbobshinigin
I just replaced all 4 of my nozzles with new Sprint 520s. With 210k on the odometer, I suspected they were original. Upon removal, I am quite certain. I had expected that changing the nozzles would quiet it down because it has a pretty consistent tapping/nailing sound. The old nozzles were super dirty, but I can tell no difference in sound with the new nozzles installed. Lifters perhaps?
The car is not yet on synthetic so that may help. Another thing to note is that the fuel temperature sensor is bad according to Vagcom. I have the part, I just need to get a stripped bolt out. I have no idea what the IQ is set at either.
Any thoughts? The car is also on jack stands in the process of getting wheel bearings replaced so I cannot drive it yet. What else can be causing a loud tap tap tap, which is throttle dependent? It increases as pedal is pressed.
