Here is the method for cutting the top bearing shell I have chosen. It is the same manner that the top crankshaft bearings are cut.
Note the #5 lower journal bearing has a center cut between the oil hole with a space to allow oiling to the top shell. I am not sure there is enough allowance to properly oil the top bearing. I still drill a pathway to the rocker galley to more directly oil the top bearing.
Here is a small modification to the bottom bearing shell to help oil 'climb' into the lower bearing shell.
I don't know if this is a reasonable improvement to warrant the time spent.
This last picture is typical wear pattern. Rotation of the cam is the same direction as the car moving forward. From the passenger side, rotation is clockwise. Both bearing shells have the oil slot toward the back of the head.
I have been approached with the issue that the annular oil slot in the top bearing shell would be going against the rotational force of the cam. This is not so.
Looking from the passenger side of the engine, the re-engineered oil galley hole would enter at about the 10 o'clock position. The top bearing shell has been cut to a .020" depth.
The purpose of the annular ring cut in the top shell is to allow oiling at the point of greatest clearance, which would be at the opposite point of the greatest wear on the bottom shell, which is about at the 7 o'clock position.
Rather than cutting an oil path in the bearing cap to the correct location for oiling, the annular ring cut gives full range for oil flow and the 2 o'clock position, which is the best location to insert oil, is automatically covered.
Also, the other nagging problem with the PD motors are the expense of the cam cap and rocker shaft bolts. It's about $100 for the set of TTY bolts.
The engineering for the set of cam hold down bolts is completed. A grade 12.9 high chrome steel with rolled threads is now being stocked. It is a reusable set.
The 8mm rocker bolt is torqued, dry, to 44 ft lbs. If installing with engine oil, reduce to 34 ft lbs. The 6mm cam cap bolts are 22ft lbs dry and 18 ft lbs oiled torque.
The set of bolts are $50. The set of top cam bearings are cost + $50 for the annular grooving.
As a judgement call, look at the top bearing shells in the pictures above. There is virtually no wear on the top bearing shell. All of the loading force is onto the lower bearing shell. If customers desire, I will replace only the bottom set of bearing shells as needed and cut the annular rings into your top shells. The top shells and the bearing cap bolts are under no force. They are only 'holding location'. Given that, there is no reason I know of that they could not be reinserted and used. I would recommend they be used in the same position they came from and marked accordingly.
