Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Mid-west USA
Mid-west USA Local discussions for those on the Mid-West US. ( Minnesota, Iowa, Wisconsin, Michigan, Illinois, Indiana, Ohio, Nebraska, North Dakota, South Dakota, Kansas, Missouri)
Old March 26th, 2019, 05:55   #856
Huskies2710
Huskies2710's Avatar
Would like to revive this thread? Anyone paying attention to what kind of diesel they are getting?
Just had a tune completed and the shop said Meijer are the only locations with non-biodiesel. I plan to go to Bolingbrook, IL Meijer to check this out.
Otherwise I'm looking into Schaeffer Oil Diesel Treat vs Opti Lube additives to add when I fill up.
Huskies2710 is offline   Reply With Quote
Old March 26th, 2019, 06:26   #857
Btravelen
What are your concerns about biodiesel? I believe IL still subsidizes the use of up to 20% bio, but that doesn't mean every supplier uses it. My '05 Passat BHW has been using the standard issue bio blend for 167k miles with no fuel related problems.
I can tell by the color of the fuel/foam while pumping it. That doesn't help if you're trying to avoid it.
Sent from my XT1635-01 using Tapatalk
'05 Stonehenge gray TDI Passat Wagon, Leather with wood. Splash guards, 3M Clear bra, Reverse sensors, Spoiler, Rear sunshade, etc..
What's a chain?
'05 Ford Excursion Limited, 6.0L PSD, Air Lifts, Bilsteins, High idle mod.
Btravelen is offline   Reply With Quote
Old March 26th, 2019, 11:18   #858
Rob Mayercik
Color? I've never noticed a color change - everywhere I fill up in NJ, the fuel is blue to blue-green, with white foam. One of the stations I use has a sticker that claims (but I see no way to verify) a 5% bio blend, and doesn't look any different.
What colors are you seeing with different blends?
2002 Jetta GLS TDI Automatic
Baltic Green/Beige Leather
Rob Mayercik is offline   Reply With Quote
Old March 26th, 2019, 16:48   #859
Btravelen
Yellow. Foam and fuel. I didn't notice for awhile after purchasing our '05 Passat TDI but traveling to states that don't encourage and use a biodiesel blend, the fuel and foam is bright and clear white. The concentration makes a difference.
What's a chain?
Old March 26th, 2019, 16:49   #860
Btravelen
BTW, I have a diesel truck so I pump a lot of diesel and travel with both. Do you object to biodiesel?
What's a chain?
Old April 16th, 2019, 05:33   #861
Huskies2710
Was just at a Meijer and did not see any sticker noting that they were using Biodiesel. Only sticker was the low sulfur one we see everywhere. Does this mean the Meijer does not use Biodiesel?
Old April 19th, 2019, 12:00   #862
andreigbs
The BP at Ashland and Fullerton sells normal D2, if you really need fuel in the city.
2014 Jetta TDI // 28xxx miles // 39 MPG & 2014 GLK 250 // 98xxx miles // 34 MPG
2014 Golf TDI // 45xxx miles // 38 MPG - buyback'ed
2004 Bora TDI // 146xxx miles // 42 MPG - sold
1997 Jetta TDI // 317xxx miles // 44 MPG - sold
1986 Golf Diesel // 224xxx miles // 48 MPG - totaled
andreigbs is offline   Reply With Quote
Old May 23rd, 2019, 10:06   #863
Huskies2710
How updated is this site?
https://www.google.com/maps/d/viewer...213447743&z=11
Reason I ask, is the Biodiesel blend is not kind to the 3.0L V6 fuel pumps over time.
Old May 23rd, 2019, 11:29   #864
MichaelB
Fuel Economy: very good
Biodiesel blends in no way shape or form will damage your fuel pump, the fact is that a biodiesel blend has more lubricity than straight D2. There are other issues with biodiesel blends but the fuel pump is not one of them.
MichaelB is offline   Reply With Quote
Old May 24th, 2019, 07:28   #865
Huskies2710
Fuel injectors....
I believe the consensus is above B5 is not recommended for these common rail engines. Obviously can't make the switch completely. Just have to stay on top of filters and oil changes.
But, the Shell station located off York Road and Ogden sells Premium Shell Diesel. No biodiesel at all. Moving forward I know I'll have the option just down the road from me. I'm still learning about what works best for this vehicle.
Page generated in 0.26938 seconds with 12 queries
[Output: 95.49 Kb. compressed to 81.14 Kb. by saving 14.35 Kb. (15.03%)]
