Old April 9th, 2019, 09:52   #1
wyopel
Default Intermittent power loss
Driving home and loss power...stepped on the accelerator and nothing happens. After the car sits and cools down to below 160 (about 15 minutes). It fires back up like nothing was wrong and and goes until it get to around operating temperature 190 or so and then it starts losing power again and eventually dies.
I have checked vacuum lines. Already replaced the one in the computer a few weeks back. I plan on swapping n75 with one from a formally working car. Will also change fuel filter. May also swap out the MAF. The EGR was deleted by a previous owner.
This did not seem to be limp mode to me...and there was no CEL. It would have power and run fine then would start losing power and eventually poop out. I have not hooked up vagcom to see if there are other codes yet. I also noticed bottom radiator hose was not getting hot...so perhaps thermostat has a problem, but it doesn't seem likely that would cause those symptoms. Temp gauge never went above normal and seemed to warm up fine too. Heat was working fine. Nonetheless it seems temp related because it starts right up and goes once it cools off a bit.
Anyone run into this sort of problem before. Any Ideas? Any suggestions other than the plan above?
wyopel is offline   Reply With Quote
Old April 9th, 2019, 18:52   #2
ToddA1
Fuel Economy: Dismal
Bad throttle potentiometer? Scan it.
-Todd
'96 B4V: Kerma tune and PP520s
'97 B4: Stock
Rabbit build
ToddA1 is offline   Reply With Quote
Old April 10th, 2019, 04:27   #3
CrazyQuantumMan
CrazyQuantumMan's Avatar
Engine dying isn't limp mode so you got that right. I'm going to bet on fuel filter. Not much in this world will stop a VE pump TDI but a clogged fuel filter definitely will. It just happens to be coinciding with the engine warming up but I don't think they have anything to do with each other. Swap that filter and report back.
Diesel in my veins, diesel in my heart.
CrazyQuantumMan is offline   Reply With Quote
Old April 10th, 2019, 13:33   #4
jackfolstam
jackfolstam's Avatar
Fuel Economy: 42mpg
How would it not overheat if there's no flow through the radiator? I'd change the thermostat soon. Maybe your coolant temp sensor is in a bubble? Is the water pump pumping?
jackfolstam is offline   Reply With Quote
Old April 10th, 2019, 20:42   #5
wyopel
Agreed. I bought the car (sedan with less than 200k) cheap a couple of months ago after my b4v was rear ended. I got a timing belt kit along with a thermostat and water pump. Just no time to do the work. I plan on flushing coolant, doing the belts, and new fuel filter. I thought I read something about it being rare for these thermostats to fail closed...but who knows. I will also swap out the temp sensor. I have lots of good parts on my wrecked B4V. I will report back when I have that sorted.
Old April 11th, 2019, 14:50   #6
ToddA1
Wait... is it just losing power or is the engine shutting off. If it’s actually doing the latter, I’d expect a restriction.
Check the fuel filter, as mentioned. Kinked hoses, etc.
-Todd
'97 B4: Stock
Rabbit build
Old April 11th, 2019, 20:23   #7
wyopel
Yep. My first thought was a fuel restriction. The car would just die. Other, possibly unrelated symptoms, like the fact that it seemed to run fine after it cooled down made me think twice, or at least consider other possible causes. I should be able to figure something out this weekend.
Thanks everyone for chiming in. I don't think I would have gotten another one of these cars (I have three now...actually four if you count the wreaked one), if the helpful experienced folks on this forum weren't there as backup.
Old April 12th, 2019, 17:15   #8
wyopel
Swapped fuel filter and no change. Pulled codes and there was a 00575 - Intake Manifold Pressure...so next is vacuum hoses and n75 swap. Engine temp was 87 degrees C.
Old April 14th, 2019, 18:21   #9
wyopel
Swapped n75 and hoses but that did not fix it. Same problem. Car heats up and then has intermittent power loss. By intermittent I mean the car pulses/surges. It's like you are taking your foot on and off the accelerator. I am wondering if something is heating up and expanding just enough to cause a boost leak. MAF?
Old April 15th, 2019, 08:18   #10
wyopel
Another symptom I just noticed. When it starts pulsing there is lots of white smoke. It did not smoke like this before and only smoke when it starts acting up after it reached operating temp. Any ideas?
Old April 15th, 2019, 15:42   #11
jackfolstam
Fuel Economy: 42mpg
Leaky intake manifold gasket? Exhaust leak/Egr leak? As the metal parts expand with heat they have more clearance?
Sent from my SM-G900V using Tapatalk
Old April 15th, 2019, 16:47   #12
wyopel
EGR was deleted by previous owner. Perhaps something is not tight. They must have swapped the manifold to do the delete. I may just take my other manifold/egr and put it on.
Old April 15th, 2019, 17:20   #13
wyopel
A new code has now popped up. So the two codes now are:
2 Faults Found:
17-10 - Control Difference - Intermittent
00550 - Start of Injection Regulation
Don't know much about this code, but perhaps timing belt has slipped a tooth? Still does't explain why it only seems to show up after engine heats up though.
B4V Loss of MPG, intermittent power loss tibbittsa VW MKIII-A3/B4 TDIs 4 March 29th, 2017 22:07
Intermittent loss of power npb VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 13 March 26th, 2013 19:49
Intermittent power loss bcautosound VW MKV-A5 Golf/Jettas 10 July 7th, 2012 22:13
Intermittent Power Loss Sootman TDI Power Enhancements 0 August 28th, 2006 15:46
Intermittent loss of power eggpacker TDI 101 3 August 22nd, 2006 08:30
Page generated in 0.13975 seconds with 13 queries
[Output: 109.68 Kb. compressed to 91.76 Kb. by saving 17.93 Kb. (16.34%)]
