Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old April 13th, 2019, 08:06   #1
deck60
TDI(s): 2001 jetta
Default looking at a 13 or 14 tdi wagon what issues should I loook for
so my 01 tdi trans gave out and I am not going to fix it but I need something that gets great mileage so I am looking at 13-14 tdi wagon but need to know what should I look for
1 should I get one with emmisions fix done or not and are their programmers to remove it??
2 transmission issues
3 timing belt issues
4 anything else I need to know
the good the bad and the ugly all help will be appricated
deck60 is offline   Reply With Quote
Old April 13th, 2019, 10:53   #2
Turbski
1. If you're buying from any dealer they would have already done the fix. If you buy private party then the only reason to do the fix is for the extended warranty, which is pretty great.
2. Transmissions are solid and have 0 issues on these as long as the services are performed. The manual tranmission has lifetime fluid, but a lot of people do a fluid change at 120k. I did and do notice a difference in shifting. The DSG trans needs to be serviced every 40k miles. If you skip this, bad things happen! Either have the dealer do it ($400 I think?) or buy VCDS and do it yourself, it isn't hard.
3. No issues with timing belts. Good to 130k miles. As timing belts go, not too difficult, but I would say not for someone that hasn't done one before. Replace the idler pulleys as well, dont cheap out! IDparts has a great kit for the timing belt. Don't forget, the motor mount bolts are torque to yield you should always replace these.
4. These cars have 2 major issues.
a. Intercooler icing - if you live in a climate that gets fairly cold in the winter, the
EGR will end up causing ice to build up in the intercooler. I live in Denver and
have had this issue multiple times this winter. VWs fix for this does not work. My
advice is to delete the low pressure EGR to solve this issue. I removed my EGR
system entirely. It will take longer to warm up your engine, if this is an issue for
you, get a frostheater. Mine has been great.
b. High pressure fuel pump (HPFP). These have been known to grenade and take
out the entire fuel system. Make sure to always fill up at high volume diesel
stations. I prefer to fill up at a truck stop near me. This will get you fresh diesel
and help keep your HPFP healthy. This is the main reason it's a good idea to do
the fix to get the warranty as it covers the engine, emissions, and fuel systems. If
you decide not to do the fix, I highly recommend the cp3 injection pump swap kit
from darkside developments. The cp3 is extremely reliable and no longer needs to be timed with the engine.
Turbski is offline   Reply With Quote
Old April 13th, 2019, 11:27   #3
deck60
TDI(s): 2001 jetta
wow great info looks like I will be doing some research tonight I really want a manual need to research the hpfp more I would like to to the egr dpf wolfsbur has a nice kit
Old April 13th, 2019, 14:44   #4
Turbski
Yeah I have the manual and I love it. The gearing is great and the mpgs are fantastic. If you do a lot of highway driving with minimal need for shifting you will get better mpgs with the manual (I think). I have a friend with the dsg and we drive the same route, I end up with better mpgs, I'm guessing due to the weight difference in the transmissions.
If you go with the 6 speed I highly recommend the sigma six short shifter. I was not a fan of the stock shift feel.
Edit: If you don't plan on modding the car, I would get the emissions fix done so you don't have to worry about the HPFP. This is a $6000+ disaster waiting to happen if you don't have the warranty or if you don't do the cp3 swap.
Old April 13th, 2019, 16:10   #5
deck60
TDI(s): 2001 jetta
the only mods are egr and dpf delete
Old April 14th, 2019, 18:11   #6
Turbski
You might want to check with a VW dealer, but I'm fairly certain a DPF and EGR delete will void the warranty.
Pricing of 13-14 jetta sportwagen tdi after fix ? mag1 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 113 April 4th, 2019 04:04
13/14 Fixed Passats - ANY ISSUES? r90sKirk VW Passat Family (NMS and B7) TDIs (2012+) 19 August 13th, 2018 09:39
13 - 14 TDI Down and Midpipe sound antioch01 TDI Power Enhancements 1 March 30th, 2015 13:52
Page generated in 0.14939 seconds with 13 queries
[Output: 73.27 Kb. compressed to 64.15 Kb. by saving 9.12 Kb. (12.45%)]
