Old January 6th, 2019, 17:19   #1
mac11
TDI(s): 04 Passat
Default 04 Passat auto trans was 4 spd
I believe what I read was the 04 Passat had a 4 speed auto and there was a to converter lockup somewhere in there that simulated another gear? Please correct me if I’m wrong there.
When in tiptronic mode should I see 4 or 5 “gears” I do ages on the led dash?
mac11 is offline   Reply With Quote
Old January 6th, 2019, 17:33   #2
mac11
TDI(s): 04 Passat
There’s suppos s to be a question mark in that title. ��
Old January 6th, 2019, 19:49   #3
Uberhare
Uberhare's Avatar
TDI(s): Too many.
Fuel Economy: Depends on what I'm towing!
It's a 5 speed auto with lockup converter.
2004 Passat W8 Variant, awaiting BHW swap
Retired: 2005 Passat BHW Variant w/01E 6 gang
Uberhare is offline   Reply With Quote
Old January 6th, 2019, 19:53   #4
mac11
TDI(s): 04 Passat
5 actual gears. Ok.
So I just picked it up and drove about 100 miles home.
Got it for a good price so the couple issues it has aren’t a huge deal and I will work them out.
The thing runs and shifts well with 2 noteable exceptions.
When shifting into drive and when downshifting our of 5 it clunks hard.
Is this the trans starting to go? Is it just a solenoid that can be replaced? Something else?
277k miles.
Old January 7th, 2019, 07:53   #5
PickleRick
PickleRick's Avatar
Any cels? Possibly just an issue with cracked/worn/torn motor and/or transmission mounts.
If no cels get her up on a lift and check all these mounts and front snub mount and service the transmission. Dropping the pan to see what's inside can reveal a lot if you're not getting any cels. If it's clear of debris id change the filter and refill with proper fluid.
Another source of clunking between gears are worn/torn/cracked control arm bushings and/or ball joints. Each front tire has 4 ball joints. It makes the car handle better than most other fwd cars out there but it also means more stuff to wear out.
It's possible with that many miles all motor/tranny mounts and conrol arms are due for replacement.
Nobody exists on purpose. Nobody belongs anywhere. We’re all going to die. Come watch TV.
PickleRick is offline   Reply With Quote
Old January 7th, 2019, 08:38   #6
mac11
TDI(s): 04 Passat
No CELS, just a brake pad light. If it were just a mount that would make my life a lot easier. I'll get it on the lift ASAP.
Any ideas why the cruise control acts weird? Or where to start diagnosing it?
It will set every time. Runs on cruse for 10-30 seconds then it clicks off.
Old January 7th, 2019, 10:14   #7
johnboy00
Check out this thread. N91 solenoid and sometimes the MAF can be the cause. These are for gassers but the transmission is basically the same except for the gear ratios.
https://www.passatworld.com/forums/b...-followup.html
John
2005 Passat Wagon
2004 Jetta Auto
2003 IBW
1999.9 Golf (for parts)
johnboy00 is offline   Reply With Quote
Old January 21st, 2019, 17:59   #8
mac11
TDI(s): 04 Passat
Can I pull a N91 out of any 01M?
04 TDI Auto Trans Testing 50mpgtdi VW B5 Passat TDIs 7 March 15th, 2018 12:41
WTB: 04-05 Passat TDI Auto trans vwtdtech5052 Private TDI Items for Sale/Wanted 0 June 8th, 2017 07:37
Need 2003 ALH Auto Trans work (or 5 spd swap) - Delaware BlueJay83 Upgrades (non TDI Engine related) 1 August 11th, 2016 12:36
FS: GMR auto trans from '04 passat wagon 180K miles algirdas Private TDI Items for Sale/Wanted 5 June 13th, 2014 19:06
DSG auto trans vs 6 spd manual? perrygreene TDI 101 18 July 12th, 2008 13:25
Page generated in 0.08957 seconds with 11 queries
[Output: 85.27 Kb. compressed to 73.61 Kb. by saving 11.66 Kb. (13.68%)]
