Go Back   TDIClub Forums > Classifieds/For Sale/Wanted > TDI Cars for Sale/Wanted
TDI Cars for Sale/Wanted VW TDI/Diesel cars for sale and wanted.
Old September 27th, 2018, 06:30   #1
MyWifesTDI
Fuel Economy: Mostly above 50 MPG...
Default 2002 Jetta GLS Wagon for sale Missouri
I have owned this vehicle since 2009, bought from original owner in Texas. Maintained as listed below. 330K on vehicle now, consistently 45 MPG up to 48 MPG, completely stock motor, and uses ~1/2 qt. oil every 10K Original motor, turbo and 5-speed manual transmission. Has some minor dings and clear coat damage. Baltic Green/Beige mouse hair cloth. Most if not all work outside of filters and oil changes were done by a TDI guru. Heater box leaks, so not the strongest heat in winter. 16K left on timing belt. I am asking $2000, and is has just passed Safety/Emissions in Missouri.
154K-Oil change and filter- 4 qt. Castrol 5W-40 and Purolator filter
154K-#2 Glow Plug and Harness replaced, Front Lower Control Arm Rear bushings, right fender well liner replaced, 4-Whell alignment-CarDoc
157K- ALH Timing Belt kit: water pump, tensioner, rollers, stretch bolts and accy. Belt-VW Parts-CarDoc
160K-Service: Replaced Air Filter, Fuel filter and Cabin filter-VW parts, 4.25 qt. Mobil 5W-40 TDT-MGB
161K Alternator and pulley, Bosch AL0189X 120 Amp-CarDoc
161K-Replace battery, Interstate 85 Month MTP-H7-CaDoc
170K- Oil Change-Mann Filter and 4.25 qt. Mobil TDT 5W-40-MGB
175K-Bilstein Touring Class Struts/Shocks, Installation kit (MetalMan)-CarDoc
185K- Service: Replaced Air Filter, Fuel filter and Cabin filter-VW parts, 4.25 qt. Mobil 5W-40 TDT-MGB
193K-Front brakes and rotors (ATE?)-CarDoc
197K-Injection Pump rebuilt at DFIS, renew timing belt and tensioner-CarDoc
200K- Oil Change-Mann Filter and 4.25 qt. Mobil TDT 5W-40-MGB
203K-Replace vacuum line turbo to actuator-CEL 17964-CarDoc
205K- Oil Change-Mann Filter and 4.25 qt. Mobil TDT 5W-40-MGB
209K-Replace headliner at Color Match
214K-Rear Brakes and rotors (ATE?)-CarDoc
216K-Replace Brake light switch-CEL 16955-MGB
218K-Lower subframe and replace bushings-CarDoc
220K-Replace Air and Cabin Filters-MGB
225K- Oil Change-Mann Filter and 4.25 qt. Mobil TDT 5W-40-MGB
234K-Replace Drivers Side mirror, replace Large A/C Cooling fan, evac system, dye installed-CarDoc
235K- Oil Change-Mann Filter and 4.25 qt. Mobil TDT 5W-40-MGB
236K-Replace Temperature Sending Unit, repair aluminum water flange seals on cylinder head, vacuum pump seals-CarDoc
240K-Replace Fuel Filter-VW part-MGB
245K- Oil Change-Mann Filter and 4.25 qt. Mobil TDT 5W-40-MGB
246K-ALH Timing Belt kit: water pump, tensioner, rollers, stretch bolts and accy. Belt-VW Parts-CarDoc
255K-- Oil Change-Mann Filter and 4.25 qt. Mobil TDT 5W-40-MGB
257K-Replace lower right Ball Joint, and Cyl#1 Glow Plug-CarDoc
265K- Oil Change-Mann Filter and 4.25 qt. Mobil TDT 5W-40-MGB
267K-Replace MAF Sensor (VW Part)-MGB
268K-Replace Thermostat (VW Part) and plastic water neck-CarDoc
275K- Oil Change-Mann Filter and 4.25 qt. Mobil TDT 5W-40-MGB
285K- Oil Change-Mann Filter and 4.25 qt. Mobil TDT 5W-40-MGB
288K-Replace #3 Cyl. Glow Plug, drain and refill Manual transmission-CarCoc
294K-Replace Inst. Light rheostat-MGB
295K- Oil Change-Mann Filter and 4.25 qt. Mobil TDT 5W-40-MGB
295K-Drivers door latch replaced, dash lamps replaced-CarDoc
297K-Replace Shifter End Bushings-aftermarket kit-CarDoc
305K- Oil Change-Mann Filter and 4.25 qt. Mobil TDT 5W-40-MGB
317K- Oil Change-Mann Filter and 4.25 qt. Mobil TDT 5W-40-MGB
320K-Replace Air Filter (VW)-MGB
328K-#2 Glow Plug, Front Brake pads &rotors, lube calipers, HVAC control lights replaced-CarDoc
MyWifesTDI
2004 Jetta GL (Jill) 2002 Jetta GLS Variant (Mike)
All work and no play is no good at all...anonymous
MyWifesTDI is offline   Reply With Quote
Old September 27th, 2018, 15:57   #2
Mike in Anchorage
Mike in Anchorage's Avatar
Pics will help garner interest for you. Or a craigslist link to pics.
~ I'm selfish, impatient and a little insecure. I make mistakes, I am out of control and at times hard to handle. But if you can't handle me at my worst, then you sure as hell don't deserve me at my best. Marilyn Monroe
2015 Tornado Red Golf TDI Sportwagen SE, new on 2 SEP 2017, DSG, big sunroof. Lovin it!
Mike in Anchorage is offline   Reply With Quote
Old September 28th, 2018, 08:52   #3
MyWifesTDI
Not familiar with how to URL for photo link, and no Craigslist yet.
MyWifesTDI
Old January 9th, 2019, 15:57   #4
MyWifesTDI
Posted 2 Photos in Dyno/Power photo area ind ALH 90 hp.
MyWifesTDI
Old January 11th, 2019, 12:57   #5
May-39
TDI(s): alh wagon
pm sent
03 5spd Wagon
2.5 downpipe, egr delete, race pipe, OMI,
T-4s, RC3, Bilstein T.C., TT control arms, tinted,hitched,frostheater,04 console conv,
ecodes/euro switch, skid plate...the usual..
May-39 is offline   Reply With Quote
2002 Jetta GLS TDI Wagon For Sale diesel_dame TDI Cars for Sale/Wanted 1 September 28th, 2014 19:44
For Sale - 2002 Jetta Wagon GLS TDI ADTOTA TDI Cars for Sale/Wanted 6 January 4th, 2010 12:27
2002 Jetta GLS wagon for sale Mitchell TDI Cars for Sale/Wanted 8 November 5th, 2006 21:42
2000 Jetta GLS TDI For Sale in Missouri Holmie TDI Cars for Sale/Wanted 13 June 15th, 2006 15:23
2002 Jetta wagon GLS TDI for sale kailei Private TDI Items for Sale/Wanted 10 August 27th, 2002 20:42
Page generated in 0.14560 seconds with 11 queries
[Output: 74.52 Kb. compressed to 66.27 Kb. by saving 8.25 Kb. (11.07%)]
