Old September 3rd, 2012, 16:47   #31
CharlieT
Sorry to be a pain, but WRONG and WRONG. I am trying to clean up this thread so that we get the facts straight.
None of the BHWs have M14s. They are all M16 according to ETKA.
The very early B5 passat's (1999/2000) with gas engine had the M14 bolts. From 2001.5 onwards they were all M16.
So, for BHWs (2004/5), you need 2x 4B0407643A - M16 x 1.5 x 72mm
And you need to torque them to 140 ft lbs (190Nm) + 180 deg (1/2 turn)
2012 NMS TDI SEL, 39k
CharlieT is offline   Reply With Quote
Old September 3rd, 2012, 16:59   #32
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Fuel Economy: Great!
So why does MoGolf's procedure have torque values for BOTH 14mm and 16mm bolts? Sorry, but I did misstate Ft-lbs instead of Nm in my posts.
-George Bernard Shaw
Old September 3rd, 2012, 17:17   #33
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
Mo Golf may have been confused. Don't you think it is strange to have two different bolt torques to preload a bearing? That is exactly what that bolt is there for. Charlie is correct.
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline   Reply With Quote
Old September 3rd, 2012, 19:41   #34
CharlieT
Because the Bentley manual for B5s we all use is from 1999 to 2005 models, and so cover the early models with M14, and all the later models with M16.
The TDIs (BHW) were only made from 2004/5, and so only used M16 bolts.
Yes, you incorrectly quoted 190 ft lbs + 180, which likely result in a failed bolt and some disappointment for anyone who tries that.
The correct torque is 140 ft lbs (190Nm) + 180 deg
Old September 3rd, 2012, 22:37   #35
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Mea culpa.
Old September 4th, 2012, 05:21   #36
50harleyrider
Mine definitely has the M16 and 140 ft-lbs + 1/2 turn is friggin tight! I put new tires on the car saturday and so far for reasons unknown to me, the ASR light hasn't come back on with the Autozone axle. I am rebooting my factory axle just in case. What's the trick to separating the cv joint from the axle. I tried a slide hammer with it hooked onto the used bolt but no workie loosie. Just keep on hammering?
50harleyrider is offline   Reply With Quote
Old September 4th, 2012, 05:25   #37
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
You need to remove the clip under the boot, so the outer joint is not being 'pinched' in place, and then smack it with a hammer.
oilhammer
www.cardocautomotive.com
Old September 4th, 2012, 11:25   #38
50harleyrider
I didn't see a clip holding the cv joint under the boot when I got the boot cut off and disposed of. How is it made and where is it? does the whole cv joint come off the axle intact? I didn't see any lock ring in there.
Old September 4th, 2012, 11:26   #39
oilhammer
oilhammer's Avatar
Look closer. You may have to wipe some grease out of the way to see it. I've replaced lots of B5 outer boots over the years, LOL.
oilhammer
Old September 4th, 2012, 12:11   #40
50harleyrider
Thx Oilhammer-your patience with us "amateurs" must run thin. I need to up my intelligence a notch or two if I'm gonna graduate from my B4. If the B5.5 wasn't so darn smooth and quiet I wouldn't have to.
Old September 4th, 2012, 12:25   #41
oilhammer
oilhammer's Avatar
Haha, no I'm here to help.... even if it does wear my patience thin sometimes .
You may have to give that joint a good WHACK. I lock the axle in a big [non-Chinese] bench vise, bolted to a big heavy [non-Chinese] workbench.
oilhammer
Old September 4th, 2012, 16:34   #42
1854sailor
Resident Curmudgeon
1854sailor's Avatar
With a big heavy [non-Chinese] hammer??
Old September 5th, 2012, 05:14   #43
oilhammer
oilhammer's Avatar
You betcha!
oilhammer
Old January 5th, 2019, 21:06   #44
richmondvatdi
Are there any hints or tips for getting the passenger side axle out of the hub? Driver side came out in no time, but I can't get the tip of the passenger side axle to clear the hub no matter where I move the other end or where I position the steering wheel. I hate to start disconnecting stuff that will require an alignment when I'm done.
2005 Passat TDI Wagon, 5-speed, 230,00 miles (9/1017)
2003 Jetta GL TDI Wagon, 5-speed, 340,000 miles (9/2017)
2003 Jetta GLS Wagon, 5-speed (conversion), 250,000 miles (9/2017)
2013 CC Sport, 6-speed, 2.0 TSI, 78,000 miles (9/2017)
2004 Phaeton W12, 108,000 miles (9/2017)
richmondvatdi is offline   Reply With Quote
Old January 5th, 2019, 21:52   #45
DeliveryValve
Did you remove the heat shield on top of the axle flange transmission side? That will allow you to move the axle to the side to give you more room to get it out of hub.
- Richard-
2005 Passat TDI GLS Wagon 207,xxx miles - Chainless
DeliveryValve is offline   Reply With Quote
Axle Replacement philngrayce VW MKV-A5 Golf/Jettas 17 August 25th, 2012 07:03
CV axle replacement help CollinGVT VW MKIII-A3/B4 TDIs 7 October 8th, 2011 14:20
Axle replacement ekkoh99 VW B5 Passat TDIs 16 June 17th, 2010 20:19
Axle Replacement F/R weluvlife VW MKIV-A4 TDIs (VE and PD) 3 September 25th, 2007 01:03
Axle replacement? Jeff54 TDI 101 3 October 4th, 2006 19:50
Page generated in 0.17108 seconds with 11 queries
[Output: 131.16 Kb. compressed to 109.24 Kb. by saving 21.92 Kb. (16.71%)]
