Old August 24th, 2012, 11:21   #16
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
No dealers use Bentley stuff. That is for the DIYr.
erWin would be the closest thing you could get to ELSAweb.
oilhammer
www.cardocautomotive.com
Old August 24th, 2012, 12:08   #17
johnboy00
Since you didn't specifically mention it: You are replacing the axles with OEM new or rebuilt units, correct? Most of the Chinese aftermarket axles cause annoying vibrations in gear at idle.
If you have aftermarket axles, think twice and then bring them back.
John
2005 Passat Wagon
2004 Jetta Auto
2003 IBW
1999.9 Golf (for parts)
johnboy00 is offline   Reply With Quote
Old August 24th, 2012, 12:11   #18
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Fuel Economy: Great!
Thanks for the heads up OH. I stand corrected!
-George Bernard Shaw
Old August 27th, 2012, 06:42   #19
50harleyrider
I 've had really good luck with Autozone's stuff. We need to support Autozone or they'll end up with Advance garbage. The store I went to get these items was dead. Autozone is really trying hard to give us good products. The starter I just bought from them was remand in the US. I installed the right cv axle yesterday and no vibrations. The box said they were remand in Mexico. I don't buy any aftermarket Chineese products.
50harleyrider is offline   Reply With Quote
Old August 27th, 2012, 10:23   #20
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Were they rebuilt VW OEM axles?
Old August 27th, 2012, 13:24   #21
50harleyrider
how would one know-see if I can find the VW logo stamped into it?
Old August 27th, 2012, 16:21   #22
thundershorts
if its an autozone axle, it won't be A Vw oem axle.
"You can't argue with a fool..."
thundershorts is offline   Reply With Quote
Old August 27th, 2012, 17:55   #23
1854sailor
Resident Curmudgeon
1854sailor's Avatar
I don't think that there is anything stamped into the axle tube. VW axles have a white label on them with the barcode and part number. If it was remanufactured, that will be gone, so there's no way to tell until/unless it starts vibrating. Good luck!
Old August 27th, 2012, 22:30   #24
thundershorts
It could be a Chinese axle reman in Mexico. Often the vibration shows up after 5000 miles if not right away with the non oem replacement stuff.
Old August 28th, 2012, 06:12   #25
50harleyrider
I'll post up again in 5k and we'll see. Until I get junk from Autozone, I'll continue using them. I'm at 40k on their B4 starter.
Old August 30th, 2012, 23:43   #26
jables
TDI(s): B5.5 Passat
I just got axles from firestone. I needed them last minute for a road trip and they put them on the same day.
I haven't noticed excessive vibration at idle and the price was fair. Lifetime warranty on the axles and 1 year on the labor.
jables is offline   Reply With Quote
Old August 31st, 2012, 05:28   #27
oilhammer
oilhammer's Avatar
Which on Chinese axles means a lifetime of replacing them.
You'd better get your old axles back if you can.
oilhammer
Old August 31st, 2012, 07:24   #28
50harleyrider
See my other thread on ASR light after axle change. Maybe it was a big mistake to use the Autozone one: http://forums.tdiclub.com/showthread.php?t=362187
Old September 3rd, 2012, 12:27   #29
CharlieT
1. The bolt is 14mm in diameter, 72 mm long.
2. Run, do not walk away from Billco Motors. That is a single use stretch bolt
and it must be replaced. Unless, of course, you are willing to risk major
damage to your front suspension.
3. The part number is 4B0407643A. $10.00 at www.worldimpex.com.
Good luck!
Just to avoid future confusion, the part number is correct, but the Bolt is definitely M16 x 1.5 x 72mm long. Not 14mm as shown above.
2012 NMS TDI SEL, 39k
CharlieT is offline   Reply With Quote
Old September 3rd, 2012, 12:49   #30
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Some are 14mm, some are 16mm. 190 ft-lbs + 1/2 turn for the 16mm, 115 ft-lbs + 1/2 turn for the 14mm.
Axle Replacement philngrayce VW MKV-A5 Golf/Jettas 17 August 25th, 2012 07:03
CV axle replacement help CollinGVT VW MKIII-A3/B4 TDIs 7 October 8th, 2011 14:20
Axle replacement ekkoh99 VW B5 Passat TDIs 16 June 17th, 2010 20:19
Axle Replacement F/R weluvlife VW MKIV-A4 TDIs (VE and PD) 3 September 25th, 2007 01:03
Axle replacement? Jeff54 TDI 101 3 October 4th, 2006 19:50
Page generated in 0.15770 seconds with 11 queries
[Output: 128.54 Kb. compressed to 107.08 Kb. by saving 21.46 Kb. (16.70%)]
