Old April 16th, 2012, 15:07   #1
Whitbread
Whitbread's Avatar
TDI(s): Several
Default Balance shaft delete. How to and part numbers
Here's the list of PN's needed for the swap. Will be updated with pics as project progresses.
Crankshaft oil pump sprocket - 06A105209B
ALH oil pump - 06A115105B
BRM sprocket - 038115121A
BRM chain tensioner - 038115130
BRM chain - 038115230A
ALH oil pump bolt, 3 needed - N90704007
1.8T Oil pump pickup tube - 06B115251
ALH Windage Tray - 06B103623P
DO NOT FORGET TO PLUG THE BS MODULE OIL FEED HOLE!!!!
02 Jetta TDI
Whitbread Performance Innovations
-Full TDI maintenance, performance and custom fabrication services. 248-755-8118, 10AM-5PM EST M-F. Please email or call only for business inquiries. PM's are not for business communication.
Whitbread is offline   Reply With Quote
Old April 16th, 2012, 20:39   #2
nowback
would be nice to know average prices of the parts above.
I might have to do the same job on my 2005 project passat.
not sure if i would pay the price of a new gear bsm in or do a delete.
I think the only way i would do it with a new bsm would be if i can pull some
strings and get a deal from vw for the parts.
matt
nowback is offline   Reply With Quote
Old April 16th, 2012, 21:55   #3
abctdi
abctdi's Avatar
So this replaces the BHW chain driven oil pump with a BRM/ALH chain driven oil pump?
Why do that?
05 Passat GLS 2.0 PD, UnChained & Steel GPs by VW, 15" steelies, New TB/WP, motor mounts, alt pulley, trans filter, cv boots, TSB #P9/66C8, clear bra & tint, both raxles. Now only driven 1-2 times per week. 123k miles (sold)
DD is a 2012 Kia Optima SX turbo with 274 hp and 269lb-ft@1,750-4,500rpm
abctdi is offline   Reply With Quote
Old April 16th, 2012, 22:00   #4
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
Why do that?
No heavy balance shaft module to reduce engine vibration in oil pump drive system.
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline   Reply With Quote
Old April 16th, 2012, 22:16   #5
DeliveryValve
Why do that?
I would do it if you are going with a manual transmission. The use of a heavier flywheel would essentially do the same job as a balance shaft.
- Richard-
2005 Passat TDI GLS Wagon 207,xxx miles - Chainless
DeliveryValve is offline   Reply With Quote
Old April 16th, 2012, 22:18   #6
Whitbread
Whitbread's Avatar
TDI(s): Several
Why do that?
>$300 vs $1400. That's why.
02 Jetta TDI
Old April 16th, 2012, 22:32   #7
nowback
I assume thats directed at me,,,lol
I am trying to shame someone i know who owns a vw dealership into
a deal on parts.lol
but the price difference is so great i can see a alh oil pump going in
if i have to.
Originally Posted by Whitbread View Post
How's that?
Old April 17th, 2012, 05:23   #8
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
I think if you are bolting it to a manual, it should be fine. Supposedly the "maybe built, maybe not" BGW engine was made this way, and it was the exact same as the BHW otherwise but got bolted to a proper gearbox instead.
Not sure about with the slushbox, though. Someone else did one here where he machined off the balance shafts' lobes and reported it vibrated quite a bit worse that he expected.
Here's the kicker, though: my own BHW at idle never lets you forget it is a diesel. It is not bad, mind you, but it does have some vibes through the car much more than the 1.8t engine in the same car. Also, my 1.9L TDI idles so smooth you'd think it stalled when coming to a stop unless you look at the tach.
So, is the idle NVH in the BHW worse because of the balance shafts, but better than it would be without at say 2500 RPM? Would negating them make it smooth(er) at idle but have an annoying buzz at 2500 RPM? I too am really curious, as I am using a BHW bottom end in a punched out ALH block for a project car... without balance shafts. But it will be bolted to a manual, although it will not use a DMF.
Interesting though.
oilhammer
www.cardocautomotive.com
Old April 17th, 2012, 05:45   #9
JFettig
JFettig's Avatar
oilhammer: don't forget Louis was using V6 motor mounts at the time. It would be enough to rattle your teeth for sure.
I am very curious to see how it will do. My 1.9L B5 definitely vibrates a little more than an ALH in a MKIV
Jon
JFettig is offline   Reply With Quote
Old April 17th, 2012, 05:52   #10
dogdots
dogdots's Avatar
TDI(s): None
The CBEA has the balance shaft module, and plenty of those are bolted to manual trans cars. I wonder why the BHW longitudinally mounted, only bolted to a ZF auto from the factory, and the CBEA transverse mounted, bolted to manuals and dsg's need balance shaft modules while they were not needed on BRM, BEW, ALH, etc. Does that extra 25cc per cylinder really make that much more vibration?
I'll be interested to see if the ALH/BHW combo in Brian's project above vibrates badly or behaves like an ALH.
Non VW: 2011 BMW 335D and 2011 BMW X5 35D, both white, 1999 Superduty 7.3 ZF 6 speed, 2007 BMW 328xi, 2003 Mini Cooper, 1977 MB 280SL, 1977 Chevy C10 454 bought new by wife's grandfather.
www.kansascitytdi.com
dogdots is offline   Reply With Quote
Old April 17th, 2012, 05:57   #11
oilhammer
oilhammer's Avatar
Not sure it is the extra displacement, but the extra weight of the pistons. Also, the PD pistons are heavier than the VE, plus they also use fatter wrist pins. Not sure about the weight of the rods, though.
oilhammer
Old April 18th, 2012, 17:45   #12
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Fuel Economy: 116 mpg(e), 36 mpg gas, 100 mpg combined
The BHW balancers are counter-rotating (only effective in the up-down axis when both are going up or down, not when one goes left and the other goes right) and driven at twice crank speed.
This indicates that they are intended to counter the power pulses (4 per two crank revolutions), not to counter the reciprocating masses of pistons and top half of the con-rods.
Single shaft, dual mass, counter rotating balancers (like in my V4 Saab / Ford) driven at crank speed are intended to counter the 'rocking-horse' effect created by the four reciprocating masses of the pistons and top of the connecting rods. As the 3-4 punch pushes the pistons down (and pushes up on the head) the mass at that end of the balance shaft fights against the block being pulled up by the head bolts. The mass at the other end of the shaft fights to keep that other end of the engine steady during the 2-1 punch.
Oh, for an inherently smooth three cylinder Otto cycle engine......
Svante Arrhenius 1896
Old April 19th, 2012, 07:08   #13
vwztips
vwztips's Avatar
So LNut, are you saying this is not a wise move to delete the BSM when going to a manual tranny?
vwztips is offline   Reply With Quote
Old April 19th, 2012, 19:43   #14
Lug_Nut
Lug_Nut's Avatar
If you will use the clutch to hold the car on a hill you'll be duplicating the added power that the auto uses in drive at standstill and you'll want for the balancers.
If you are normal and use neutral (or the clutch dis-engaged) and brakes when standing still you might not care, but do the full conversion to obtain a duplicate of the shaft-free, 2.0 PD B5 manuals that were available elsewhere in the world. Cutting the lumps off the shafts alone isn't enough.
Old April 23rd, 2012, 09:38   #15
sirpuddingfoot
sirpuddingfoot's Avatar
FWIW, I plan to do this in ours this summer. Yes, it's still chained Yes, my wife finally agreed that a 5spd would be ok when the ZF dies.
'05 Passat TDI - Ventectomy - BSM Delete - Nicktane Head with 2u Cat Fuel Filter - MaloneTuning Stage 1.5
'05 Mk4 Jetta TDI - Ventectomy - DG FMJ Panzerplate - HR Sport Springs and 28mm Rear Sway Bar - TT LCA Bushings -Nicktane 1u Fuel Filter - MaloneTuning Stage 1.5 ...for now
sirpuddingfoot is offline   Reply With Quote
Balance shaft JeffOB TDI 101 4 November 2nd, 2011 23:27
balance shaft module cajunspice VW B5 Passat TDIs 14 May 10th, 2011 12:46
balance shaft pingaloca VW B5 Passat TDIs 4 April 27th, 2010 21:16
Balance shaft brownswiss TDI 101 4 December 1st, 2009 15:16
Page generated in 0.18185 seconds with 11 queries
[Output: 133.70 Kb. compressed to 111.54 Kb. by saving 22.16 Kb. (16.57%)]
