Old July 22nd, 2010, 11:41   #1
Sprocket
Sprockette's hubby
Sprocket's Avatar
Post Frequently asked for part numbers
Here's a quick find & part #'s to a couple of known relays that have been problems for our cars. Can we start a sticky for part #'s for some of the more common parts? I wasn't sure if it would be good spot in this thread due to this being more of a "how to" thread.
Relay 219 - Power relay
Part #443951253AA
http://forums.tdiclub.com/showthread.php?t=266230
Relay 384 - Air Conditioning relay
Part #8D0919578A
http://forums.tdiclub.com/showthread.php?t=216493
5V Steel Glow Plug
Part #N10591607
Motor mounts:
8D0199379AR
8D0199382AR
Viscus coupling fan bearing
058 115 136
http://65.110.12.166/showthread.php?t=253126
2005 B5.5, TD Tuning, R783s, GTB2260VK, 6 speed O1E, BSM 2/09, Pod w/ 40 PSI & EGT Gauge, Thor Skid Plate, Cat FF, Euro switch
1996
B4V, 2.0L w/ BHW pistons, Rosten Rods, Girdle, 11mm, GTB1756vk, RC6, PP764s, .622 5th, Colt Cam II, Ecodes W/leveling motors & Euro switch, fog lights, Koni Yellow, Cat FF, Whitbread 2.5" DP, exhaust, FMIC
Sprocket is offline   Reply With Quote
Old July 22nd, 2010, 12:05   #2
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
I will leave that to MOGolf, very good idea though.
Here is one I'd like to see in that thread:
078-129-797 'clamp'
This is one of the 4 air cleaner lid clips that seem to be missing on a lot of B5s that come in here .
oilhammer
www.cardocautomotive.com
Old July 22nd, 2010, 12:53   #3
johnboy00
Great Idea!
Alternator pulley 022-903-119D
John
2005 Passat Wagon
2004 Jetta Auto
2003 IBW
1999.9 Golf (for parts)
johnboy00 is offline   Reply With Quote
Old July 22nd, 2010, 18:41   #4
MOGolf
MOGolf's Avatar
Default Frequently asked for part numbers
This thread is for posting known part numbers, not for asking "What is the p/n of ...". Use the "Search this thread" function to find part numbers for the part.
Bear in mind that part numbers are subject to change at any time. However, using an old part number at a good part supplier may get you the current part number if they have a cross reference. I've also experienced using a correct part number and the supplier cross referenced to a wrong part number. You have been warned. Use the information at your own risk.
If you have the ability to post the part number and a picture of the part, please do so. Obscure parts like connectors and wiring/hose retainers are good candidates for this.
I'll do a brain dump myself as time permits. I've got "a million of 'em" in my head. I might have ordered too many parts over the years.
Unchained motoring
MOGolf is offline   Reply With Quote
Old July 23rd, 2010, 09:16   #5
TooDooIoo
TDI(s): 2005 Passat
If you've done you own oil change you probably need this one if you are clumsy like me. Orange dip stick tube:
038 103 663B
Also, belly pan aka splash shield: 3b0 825 235 b
Fasteners:
3x silver 18mm fasteners: 8d0 805 121
2x black 20mm fasteners: 8d0 805 121 b
3x brown 21.5mm fasteners: 3b0 805 121
3x rubber washer: 4a0 805 137
4x plastic side screw: 4a0 805 121 a
4x plastic side snap/clip: 4a0 805 163
Instructions (http://www.myturbodiesel.com/1000q/b...ldfastener.htm)
TooDooIoo is offline   Reply With Quote
Old July 26th, 2010, 09:49   #6
LoneLIPumpeDuse
LoneLIPumpeDuse's Avatar
The INA # (the overrunning pulley part manufacturer) http://www.schaeffler.com/remotemedi...FL_Katalog.pdf
Is on Pg 18, 535 0005 10
I have found the whole pulley assembly for $90.00 + shipping from
(budda42@comcast.net)
BUDDA'S AUTO MARINE ELECTRIC in CT
Originally Posted by johnboy00 View Post
Great Idea!
04,TDI Passat Sedan,BLUE GRAPHITE PRL/ANTHRACITE
165,000mi Chainless with new bottom end. Because Habberstad VW Tooef'ed my motor Via Broken Glow Plug
stage2
The sound of TDI speed
LoneLIPumpeDuse is offline   Reply With Quote
Old October 14th, 2010, 05:58   #7
oilhammer
oilhammer's Avatar
3B1-819-425-B41 "cap"
This is the little black cap that covers one of the ECU cover's screws, the access hole in the lower windshield trim. These like to suddenly pop off and disappear into the bowels of the engine. Been doing a LOT of RC upgrades lately, and have to have a few on hand "just in case"
oilhammer
Old January 17th, 2011, 15:24   #8
truedubber
Please forgive the dumb question but..
Shouldn't you guys be listing the engine codes with your part no.s
Surely not all B5 TDI's are the same?
truedubber is offline   Reply With Quote
Old January 17th, 2011, 15:29   #9
Sprocket
Sprockette's hubby
Sprocket's Avatar
All of the parts listed are for the North American B5.5 Passat TDI. Yes, we only have the one engine code: BHW
1996
Old January 20th, 2011, 15:01   #10
Sloppy Snood
Sloppy Snood's Avatar
TDI(s): Passsat
Fuel Economy: 31 mpg (city) / 38 mpg (hwy)
Default NGK Ceramic Glow Plugs
The NGK branded ceramic glow plug for the "2nd VW Fix (2010)" for remedying cold start issues. Plug contains metal sheathing along part of the ceramic element.
This GP will work with the original 7-volt programming but a re-flash at the dealer is recommended (required if 5-volt steel glow plugs were installed in the first VW attempt to fix cold start issues)
N105 916 09
Got Meleagris gallopavo silvestris?
Don't know what a "Snood" is? Click Here and Move Cursor Over the Beak
'05 VW Passat TDI GLS - The Unofficial TDIClub VW B5.5 Passat oil pump balance shaft crybaby!
Sloppy Snood is offline   Reply With Quote
Old January 20th, 2011, 15:04   #11
oilhammer
oilhammer's Avatar
Nope, but all ours are. This thread is really just for the 2004/2005 BHW cars.
oilhammer
Old February 14th, 2011, 16:25   #12
rallyruss
rallyruss's Avatar
Torque converter 01V 323 572 B
and the seal 01F 321 243
this is for the ZF trans in our B5.5 passats. trans code is GMR.
98 TDI jetta BillyHDs, Softsports, 16"wheels, corrado brakes, running B99. PP520s and chip to match and some other stuff....250k+
(Hers) 05 Passat TDI GLS wagon. Unchained, Koni FSDs, RC2, audi S4 wheels and full tint.
rallyruss is offline   Reply With Quote
Old April 5th, 2011, 21:31   #13
samspock
AC Condensor fan: 8D0 959 455 R
'15 Jetta TDI S Black
Gone but not forgotten:
'05 Passat TDI GL Shadow Blue
'76 MB 240D "The Bird Slayer"
samspock is offline   Reply With Quote
Old April 22nd, 2011, 08:07   #14
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
Seal material for cabin filter housing (replaced under a TSB):
AKD 497 010 04 NAR
It's about $10 for a length of this that will do 3 cars.
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline   Reply With Quote
Old June 23rd, 2011, 06:03   #15
oilhammer
oilhammer's Avatar
Charge air tubing seals:
3C0-145-117 (the smaller one)
3C0-145-117-F (larger one)
Smaller one is only at the turbo outlet, the larger ones are everywhere else.
oilhammer
Page generated in 0.15615 seconds with 10 queries
[Output: 129.99 Kb. compressed to 107.72 Kb. by saving 22.27 Kb. (17.13%)]
