Longeyr1
I apologize for bringing up what might appear to be a repetitive topic. I have a 2006 Jetta TDI with a DSG transmission. I like most of you on this web site like to perform all maintenance myself as it allows for me to sleep better at night and feel that it was done correctly.
In the past I have done everything to a vehicle but as the newer cars get more complicated I will admit I’m apprehensive with performing some of the maintenance myself. I would like to know if I could successfully perform the DSG service without bringing it to the dealer. I have read on how to perform this service and admit it looks simple. I just don’t have as VAG-Com and really don’t want to purchase one. This might be a stupid question but how critical is it to have the vehicle (transmission) reach the desired temperature to drain the excess fluid? Has anyone performed this service without the use of a VAG-Com? It just boggles me that such an easy procedure can be so complex by the last step requiring the fluid to reach a certain temperature to drain the excess fluid. What about the “Tranny reset” I read in an old thread that the tranny needs to be reset. Is this true and is it performed through the use of a VAG-Com? If you do change the fluid without resetting the tranny what are the impacts?
I currently perform all my maintenance oil, fuel, air filters, front, rear rotors and brake pads and have switched my shocks/struts from the stock to the Bilistens HD. I’m just trying to keep my baby out of the shop from the hands of people that could care less about performing accurate maintenance with care. I currently have 71,000 miles and had a bad experience with the dealership the first time I had the 40K DSG service done I’m just trying to prevent another as my 80K DSG service is fast approaching. If I need to have this service performed at dealer does anyone know of a respected service garage in my area southern New Hampshire?
