Closed Thread
Old December 22nd, 2008, 12:51   #46
maktas
maktas's Avatar
Not to clutter this thread, however, could someone post a detailed diagram of the BS assembly? I am curious to understand more about the parts involved.
2005 Passat TDI GLS, ST tune (gone after GP recall flash ), Reflex Silver, aftermarket HID 5000k (both headlight and fogs), chainless as of 4/18/09
maktas is offline
Old December 22nd, 2008, 13:11   #47
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Those diagrams have been posted in the other threads, and there are several pictures as well.
oilhammer
www.cardocautomotive.com
oilhammer is offline
Old December 22nd, 2008, 17:53   #48
maktas
maktas's Avatar
Well I found this on this page on the other thread by MoGolf, I would love to see what part#/description each of the numbers are associated with (on the Bill of Material) then using the new parts list for the module I can cross reference to see all of the parts we are talking about. I am guessing its parts 1-> 4...18->28. There is no chain so I am guessing this is pretty close to the new BHW BS module.
http://pics.tdiclub.com/data/3629/BR...y_overview.JPG
maktas is offline
Old December 22nd, 2008, 18:05   #49
oilhammer
oilhammer's Avatar
There is a detailed parts list in MOGolf's pdf document on the procedure. Much of it is hardware. The 3 main pieces are the 'housing' (which is the BS module with oil pump) and 2 gears. Everything else is hardware, and the front crank seal.
All the parts in question that get replaced are in that picture basically. But that is NOT a picture of a BHW engine. But it is the same basic layout.
oilhammer
Old December 22nd, 2008, 19:19   #50
MOGolf
MOGolf's Avatar
The equivalent parts of 1, 2, and 18-32 in that picture are covered in the parts list in the PDF. There is no 3-4 for the BHW module. The new BS module includes 1, the equivalent parts of 18-24 (oil pump and its pick up), and 27-31. The various sized bolts (2 and 26), and gears (25 and 32) are listed separately.
MOGolf is offline
Old December 22nd, 2008, 20:17   #51
maktas
maktas's Avatar
Excellent, thank-you guys. I finally got around to looking at the PDF, we all appreciate the work you guys have done.
maktas is offline
Old December 22nd, 2008, 22:44   #52
leicaman
leicaman's Avatar
Fuel Economy: Much better than the average car... :o)
What I think we should start is a list of people who are qualified (ie gurus) who have the technical experitise who can replace the oil pump chain with the oil pump gear assembly. We all know that Oilhammer and MoGolf have done the procedure and are of course fully qualified. As folks get 'em fixed, we should make a note of who really knows how on earth to get this operation done properly. I don't think it would be out of the way to make it a sticky or something on that order.
2015 Golf SE TDI with DSG, 61k.
2005 Passat GLS TDI - RIP, 208k miles. Many good memories and friends made with this car.
leicaman is offline
Old December 22nd, 2008, 22:49   #53
Route 66
TDI(s): 2005 VW
I was thinking Jason TDI.
Route 66 is offline
Old December 24th, 2008, 13:49   #54
MOGolf
MOGolf's Avatar
Default PDF updated
I updated the PDF with minor revisions. Reduced picture size of BS module installed to properly fit the page, included pictures of T10053 seal installer and 3393 subframe alignment pins.
Noted that I need to get pictures of using these tools.
MOGolf is offline
Old December 26th, 2008, 08:25   #55
rarmstrong
Originally Posted by aja8888
Mine has *noise* at 54K. My friend's 2005 TDI Passat wagon in Connecticut has *noise* at 31K. This is all over the park with respect to chain/tensioner wear and noise.
Can anyone describe what the said noise sounds like? My 04 has 78k on it so far...been a decent car so far with only a few things while under warranty... motor mounts, AC relay...and then alternator went out after warranty. I'm wondering if I too will have the bs problem.
Thanks!
Rob Armstrong
Charlotte, NC
2004 Passat GLS TDI PD 161k UPSOLUTE'D and UNCHAINED!!
2006 Honda Odyssey EXL 100k
2003 Honda S2000 42k Silverstone w Red interior
rarmstrong is offline
Old December 26th, 2008, 08:50   #56
MOGolf
MOGolf's Avatar
Refer to the other threads.
MOGolf is offline
Old December 26th, 2008, 18:51   #57
cspeter8
Originally Posted by MOGolf
Edit to add:
World IMPEX has put together a kit price of the parts for those of you who are unable to get to oilhammer for help.
Geared Balance shaft module kit
I have no association with the company.
Cool. A question: How much would purchase of all the machined special service tools cost? I could not find the tool with part# 3359 at www.metalnerd.com. Is the cost high enough to entertain the idea of 'renting' the tools for shipment from anyone who has them already?
2004 Passat TDI tan sedan, ~200,000 miles chainless/ westfalia hitch, manual trans swap.
2001 Jetta TDI blue sedan, ~225,000 miles - ~sold
2005 Jetta TDI blue wagon
~sold
(Greasecar kits on all)
cspeter8 is offline
Old December 26th, 2008, 19:10   #58
MOGolf
MOGolf's Avatar
http://www.metalnerd.com/cat14.htm Second from the bottom (as of this posting).
I personally won't rent tools to anyone. The total cost of tools listed (not counting the usual sockets, wrenches, Torx bits, XZN bits, engine support, oven, blocks of wood, and heat resistant gloves) is in the neighborhood of $600 (plus or minus a few) plus shipping and tax (where applicable) and depending on sources.
MOGolf is offline
Old December 28th, 2008, 15:25   #59
DickSilver
Oilhammer: Is the kit sold by World Impex (IMPEX SKU # 935619) that you refer to in your original post, the same kit sold thru dealers? Or is it separately sourced, so as to not depend on VWOA's stocking strategy?
It is useless getting angry at your car: don't let nuthin' whup you that can't talk....
B5.5V TDI, chainless, Rocketchip 2, No EGR, 170K
2012 Golf 2.5, 4 door
DickSilver is offline
Old December 28th, 2008, 16:12   #60
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
FYI: World Impex Kit:
IMPEX SKU # 935619
BHW MODULE REPAIR KIT
Included In Kit
03G 103 295 Q differential case with gears, shafts and oil pump
03G 105 212 C replacement gear for crankshaft
03G 103 305 C balance shaft drive gear
4- N 911 213 01 bolts to attach balance shaft drive gear
5- N 106 014 02 balance shaft bolts
N 910 512 01 balance shaft bolt
N 911 234 01 bolt for balance shaft front near drive gear
N 909 775 02 bolt for balance shaft front near oil pump
038 103 085 E crankshaft seal
045 105 229 crankshaft pulley bolt
2 -N 908 897 01 bearing cap bolts
I have an e-mail into them to see if they actually have all of the above in stock (I hear otherwise).
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline
Closed Thread
Page generated in 0.30772 seconds with 10 queries
[Output: 125.90 Kb. compressed to 104.27 Kb. by saving 21.63 Kb. (17.18%)]
