Old February 8th, 2000, 12:18   #1
Karl Roenick
Default Put The EGR System to Good Use - Fit an EGT Probe On It
There seems to be enough plumbing back there that a tap should be able to be made, (pre-cooler), for an EGT probe.
Waddya think
Karl Roenick is offline   Reply With Quote
Old February 8th, 2000, 12:31   #2
HowardZ
Default Re: Put The EGR System to Good Use - Fit an EGT Probe On It
Karl, you may not realize this, but the water antifreeze in the radiator also goes to a special EGR Cooler. The exhaust gases coming from the exhaust manifuld to the EGR valve pass through this EGR Cooler.
So I think you need to tap the exhaust temperature at the exhaust manifold or just before the exhaust enters the turbo charger.
HowardZ is offline   Reply With Quote
Old February 8th, 2000, 12:41   #3
Karl Roenick
I was thinking pre-cooler, Howard.
I don't know how true the temps would be the farther the egr pipe gets from its manifold beginning, however. When is EGT highest and when is EGR flow least? If they coincide, you'd have to get your temp probe close to the egr pipe connection. Maybe just a saddle on the egr pipe close to the manifold without penetration.
Drilling a bung into the manifold for an egt probe seems problematic (ie, costly, esp if you remove it)
Old February 8th, 2000, 14:03   #4
mickey
Guest
SkyPup mentioned "wrapping" a probe on the exhaust in an e-mail. Is there a reliable, accurate probe that just attaches to the outside of the pipe? That would be ideal, but it seems unlikely to me.
-mickey
Old February 8th, 2000, 14:13   #5
Karl Roenick
I THINK VDO has a band that wraps around a pipe. I think you still have to drill a hole for the probe but you don't have to weld a bung. The strap holds it in place. The guy at SPA said the method is good enough for aviation.
Yellow 2000 Beetle
Page generated in 0.14883 seconds with 10 queries
[Output: 61.37 Kb. compressed to 53.90 Kb. by saving 7.47 Kb. (12.17%)]
