Old January 17th, 2019, 14:04   #1
apeck618
Default I want to replace my car speakers
I just picked up a 2012 golf tdi with the regular sound system, Nothing like the monsoon my mk4 jetta had. I do have the factory touch screen head unit.
Should I get 2 or 3 way speakers for the doors? Also are they 6.5inch?
What brands do you recommend. I would like a lot of bass with out having a sub-woofer.
Any feedback would be appreciated! Thanks
apeck618 is offline   Reply With Quote
Old January 17th, 2019, 17:48   #2
brownnugen
Recommend going to Crutchfield's website to figure out what fits in your car: https://www.crutchfield.com/Car/outfitmycar/mycar.aspx
brownnugen is offline   Reply With Quote
Old January 17th, 2019, 17:52   #3
PB_NB
PB_NB's Avatar
I did Alpine components in the front and Alpine 2 ways in the back. They are nice and the "S" line wont break the bank.
1999 New Beetle TDI - Bosio 1019's, Malone S4, Skid Plate, Neuspeed Sway Bars, KW V2, 19's BBS-CH, Spyder LED's, EGR Delete, VF Mounts, South Bend Clutch, B&M Shift Kit, VNT17, Custom Side Mount Intercooler, HPA Big Brakes 355mm Ft/335mm Rr, 2.5" Custom SS Straight Through Exhaust, Colt Stage 2 Cam, 3 Bar Map.
PB_NB is offline   Reply With Quote
Old January 17th, 2019, 17:58   #4
elcid86
Always a good place to start. Iíve been thinking about doing my Ď15 Golf too.
Shawn in VA/DC
2015 Golf TDI SEL DSG - White Wabbit
2004 BMW 330i ZHP - Red Rehab
elcid86 is offline   Reply With Quote
Old January 17th, 2019, 19:31   #5
PRY4SNO
PRY4SNO's Avatar
Fuel Economy: Impressive
Focal.
- 2010 GSW 6 speed TDI (296k km & counting): #farmenwagen
- 1992 Audi 80q 20v: the 20vt winter sled (long term project)
- 1990 Audi Cq 20v: #becauseracecar
PRY4SNO is online now   Reply With Quote
Old January 18th, 2019, 06:15   #6
compu_85
Gadget Guy
compu_85's Avatar
Fuel Economy: 3.3 Mi/kWh
You could also track down the factory Fender woofers. Plug and play replacement. (You'll only use 1 of the 2 voice coils in the front, but that's OK)
-J
Present:
2018 Tesla Model 3 DM. 17,000 miles.
2014 Cadillac ELR. 33,000 miles.
2013 Fiat 500e. 28,000 miles.
99.5 Jetta "GLX" TDI. 323,000 miles. Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG.
1991 Mercedes 350SDL 230,000 miles, 70,000 on engine. 18/27 MPG.
Past:
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
2004 Touareg V10 TDI. 165,000 miles. Sold to Matt98AHU w/ flat camshafts.
1988 Audi 5000S Quattro, 1992 Jetta ECOdiesel, 1991 Jetta ECOdiesel.
Thank you for giving me the BUG*PWR award. It means a lot to me!
Check out the official TDIClub Chat Room!
Originally Posted by BRUSSELS BELGIAN View Post
Maybe I should pay MYSELF to do bad work on my car!
compu_85 is offline   Reply With Quote
Old January 18th, 2019, 10:34   #7
apeck618
-J
Why would it only use 1?
Old January 18th, 2019, 10:43   #8
apeck618
Can you explain more. Is there any big difference in 2 way and 3 way?
Old January 18th, 2019, 12:42   #9
bizzle
bizzle's Avatar
No, not in a car and not in a casual listening atmosphere.
There are a couple (separate) things going on here:
The difference between components and integrated
The difference between 2way and 3way
He has components in the front, which is the woofer (big speaker) down in the door and tweeters (the little speakers) somewhere else (like up in the A pillar, for example). Installers do that for placement and focusing. The larger the speaker, the more omni directional sound is; the smaller the speaker the more directional the sound is (think of those huge subwoofers thumping away in people's cars that you can feel/hear in your own car--but you can't hear the voices unless the windows are down in both cars).
So woofers can be placed in the door without too much compromise on sound but the little tweeters need to be pointed at your ears for best results, which is why they're mounted up by your head in modern, factory locations.
The backseat isn't as important in getting that precise placement, usually, so integrated speakers are used (woofers with tweeters in the middle of them slightly off-center). That's what he has in the back. I have components in the back but setups like that require more precise placement than just having the whole setup in the panel.
The distinction between 2 and 3 way speakers comes down to how many speakers are part of the system (independent of whether they are composite or components). So far we've been discussing 2 way speakers and those are by far the bulk of car audio options for general applications. A woofer + a tweeter are what you are used to and makes placement simple. A three way speaker will usually add a midrange driver. You then need to figure out where you're going to place that third driver, how to EQ it, a more complex crossover (which also needs correct placement and additional cost), and whether the type of music you listen to even warrants its inclusion. It's main purpose is to reproduce sound better than the other two speakers with this dedicated, to-purpose speaker that can allow them to better focus on the slice of frequency they are best at.
Then there are other factors like a good 2 way is going to outperform a mediocre 3 way, but that's the gist of it.
So you're basically looking at 2 way components in the front to replace what you have in the door and pillar, and then 2 way non-components in the rear to replace the speakers in the door cards.
bizzle is offline   Reply With Quote
Old January 20th, 2019, 20:58   #10
compu_85
Gadget Guy
compu_85's Avatar
The "base" front door woofers have a single 4 ohm voice coil. The fender speakers have 2x 2 ohm voice coils. So when you plug in the base wiring, only one voice coil gets hooked up.
For the rear door woofers, both the base system and Fender have a single voice coil, with the standard being 4 ohm and fender 2 ohm.
-J
Present:
Past:
Old January 21st, 2019, 11:52   #11
apeck618
-J
I haven't messed with speakers in a long time so its why I had to ask so many questions lol. I just want it to sound good. I want alot of bass with clear audio like my Ram 1500 has. Maybe Il try to get the factor fender speakers and put them in.
Old January 22nd, 2019, 14:53   #12
compu_85
Gadget Guy
compu_85's Avatar
Check ebay, there are usually some floating around.
You'll need a pop rivet gun to install them. Be sure the seal is good, the side airbag sensor depends on the speaker making a good seal against the door.
-J
Present:
Past:
Old January 27th, 2019, 19:39   #13
garreth5
TDI(s): jetta
It depends on your budget also. I agree on checking Crutchfield. They have some good pricing.
garreth5 is offline   Reply With Quote
Old January 29th, 2019, 09:02   #14
elcid86
I really wish there were better options. Suggestions appreciated.
Shawn in VA/DC
Old Yesterday, 18:46   #15
elcid86
I added sound deadening/dampening to the door panels and inside the door. I really think it helped with the Fender speaker sound. As for now Iím pretty satisfied and will tinker with something elseólike the wifeís Ď18 Outback speakers!
Shawn in VA/DC
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
delormea397
VW MK4 How to Replace Speakers With Aftermarket terrydtdi TDI 101 29 July 22nd, 2015 20:49
How to replace front speakers and fix problem with the rear lights ? edzha90 TDI 101 0 March 7th, 2015 10:36
replace factory speakers homelessgdog VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 6 December 26th, 2012 03:17
Replace turbo or replace car ('03 jetta tdi)? coolbean1000 TDI 101 27 April 22nd, 2012 16:24
Replace speakers...help needed pisces64 Upgrades (non TDI Engine related) 2 January 3rd, 2001 12:48
Page generated in 0.15652 seconds with 13 queries
[Output: 134.93 Kb. compressed to 113.71 Kb. by saving 21.22 Kb. (15.73%)]
