Go Back   TDIClub Forums > VW TDI Discussion Areas > Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc)
Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) Discussions about alternative fuels for use in our TDI's. This includes biodiesel WVO (Waste Vegetable Oil), SVO (Straight Vegetable Oil), BTL (Biomass to Liquid), GTL (Gas to Liquids) etc. Please note the Fuel Disclaimer.
Old January 20th, 2019, 01:06   #1
StlJimmy
StlJimmy's Avatar
TDI(s): 99.5 Jetta
Default Percentage of WVO?
I have been running B100 most of the year... for the past few years and I dig using alternative fuels. I have read and debated using WVO. My problem with getting a full kit is cost. I figured I would have to run 50,000 miles for the kit to pay for itself by saving the $1/gallon it costs to make Biodiesel if I were to brew myself. Although I have never ran WVO, I want to give it a try this summer. I have a very consistent source that I can get in cubies without any water contamination. This Christmas Santa gave me injector lines heater, and will be installing soon. Word on the street is that you can run up to 30% WVO and not have any problems with the ALH. With the injector lines heater, it is tempting to run an even higher percentage. Would adding a resistor on the fuel temp sensor help? Anyone here run a %age of WVO and not have a kit?
1999.5 Jetta and 1998.5 Ram 2500 Cummins both powered by biodiesel
StlJimmy is offline   Reply With Quote
Old January 20th, 2019, 09:40   #2
GoFaster
Moderator at Large
There is no reason whatsoever to use straight vegetable oil if you are capable of making biodiesel out of it.
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
GoFaster is online now   Reply With Quote
Old January 20th, 2019, 16:26   #3
mrseadog
TDI(s): 2002 Jetta
If I recall correctly some studies have found you can safely run 5% without any issues. At those numbers it is about 1 gallon/tank.
mrseadog is offline   Reply With Quote
Old January 20th, 2019, 18:45   #4
philngrayce
Fuel Economy: 53/43/49 ('02 Jetta 5 sp)
I donít think 30% would work in cold weather. You might get away with it in the summer. If you want to run WVO, and I think thatís fine, I would get a 2 tank kit. If you donít do that, I would agree with GoFaster that biodiesel might be better, as long as you are comfortable making it.
Perhaps you can find someone selling a used Greasecar or Frybrid kit? Iíve seen them on Craigslist and ebay, maybe even on here.
philngrayce is online now   Reply With Quote
Old January 20th, 2019, 19:49   #5
jackbombay
jackbombay's Avatar
TDI(s): A4 Jetta
Fuel Economy: 57/43/32
An ALH Jetta uses so little fuel anyway why mess with "fueling it wrong"? I don't mean that bio/renewable fuels are wrong, but IMO adding WVO to your diesel tank is fairly wrong.
Hp vs. TQ
jackbombay is offline   Reply With Quote
Old January 20th, 2019, 23:01   #6
StlJimmy
StlJimmy's Avatar
TDI(s): 99.5 Jetta
I also don't think 30% would work in the cold. My car stalled out today with the 14 degree weather. I knew this cold weather was coming and tried to run all of the biodiesel out, but had maybe 1.x gallons and 4 gallons of diesel. For the summer, I would like to add some WVO into the mix. If I don't get a lot more input, I'll start with the 5% and ease my way up. I have looked for used WVO kits, and haven't had a lot of luck. I have a feelin a lot of them were not sold for the tdi? Centrifuges and biodiesel plants do pop up though. There is one of each now locally.
Old January 20th, 2019, 23:08   #7
jackbombay
jackbombay's Avatar
TDI(s): A4 Jetta
At %5 WVO you save about a third of a cent per mile on your fuel costs.
Hp vs. TQ
Old January 21st, 2019, 04:45   #8
oilhammer's Avatar
Fuel Economy: fantastic
^^^^this^^^^
www.cardocautomotive.com
Old January 21st, 2019, 05:49   #9
philngrayce
There are some advantages to WVO. Once you have the kit, there is essentially no cost for the fuel. You can burn pure WVO no matter how cold it is, in a two tank system. With biodiesel, you will probably have to mix it with dino diesel, possibly in a pretty high proportion during very cold weather. A two tank system gives you a partial redundant system, and a phenominal range on both tanks. You may not be comfortable with the dangerous chemicals and proccesses for making biodiesel; I was not.
Of course, biodiesel also has advantages. If you have more than one diesel, you can use the fuel in all of them. You can even use it in you home oil burner, if you have one. And you do not have to modify your vehicle at all. Some feel biodiesel,is more reliable. I disagree, but there is avalid argument there.
Perhaps try posting a wanted ad? I suspect there are a few of those kits just sitting in people’s garages, smelling and taking up space.
Old January 21st, 2019, 09:21   #10
mrseadog
TDI(s): 2002 Jetta
philngrayce is correct.
I have been running a 2 tank Frybrid setup for 10 years and have driven over 250,000 miles on WVO. As to the why, the numbers speak for themselves. I figure I haven't spent $20K on fuel during that period.
Water meth percentage? Cetane burner TDI 101 5 June 3rd, 2012 17:58
Percentage of diesels sold sgoldste01 TDI Fuel Economy 7 May 14th, 2012 00:37
How to estimate city/hwy percentage? lemmonsqueeze TDI Fuel Economy 7 June 19th, 2011 09:28
Mixing percentage wvo crm391 Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 4 April 23rd, 2008 06:42
Higher percentage of tdi's dweisel Sightings 4 March 20th, 2007 18:41
Page generated in 0.16080 seconds with 13 queries
[Output: 98.28 Kb. compressed to 83.54 Kb. by saving 14.74 Kb. (15.00%)]
