Old August 15th, 2014, 05:29   #31
oilhammer's Avatar
Fuel Economy: fantastic
Unless your car is already cursed with Chaxles, then you need to buy the previously mentioned NEW ones, because Volkswagen won't take your cores so you cannot get the remans.
BTDT many, many times. The Chaxle epidemic on B5s and A5s is crazy.
www.cardocautomotive.com
Old December 19th, 2014, 21:20   #32
diesel#2
I'd also add the numbers for the fuel filter valve (1J0127247J), clip (I lost this part number so ???) and O-rings(1J0198247). usually the O-rings come w/ the filter but.... ever have one go flying!?
how often should this t-valve be changed anyway? I've looked but don't see anything on how often one should change the valve (O-rings every time yes-- but the actual valve as part of maintenance? or very 3rd time or something??
diesel#2 is offline   Reply With Quote
Old March 12th, 2015, 08:55   #33
LoneLIPumpeDuse
LoneLIPumpeDuse's Avatar
Default Transmission numbers / info
http://http://www.zf.com/na/content/...atalog_pdf.pdf
http://pics.tdiclub.com/data/500/01v...escription.pdf
04,TDI Passat Sedan,BLUE GRAPHITE PRL/ANTHRACITE
165,000mi Chainless with new bottom end. Because Habberstad VW Tooef'ed my motor Via Broken Glow Plug
stage2
The sound of TDI speed
LoneLIPumpeDuse is offline   Reply With Quote
Old January 3rd, 2016, 19:09   #34
Paul in Denver
Fuel Economy: 35
2005 Passat TDI Front Wheel Bearing; Timken 51009.
From a reputable supplier..but haven't installed to confirm...yet.
Paul in Denver is offline   Reply With Quote
Old March 17th, 2018, 20:17   #35
Sprocket
Sprockette's hubby
Sprocket's Avatar
Anyone have the part number to the grommets that you have to remove to get to the upper strut nuts? There are two per strut. Mine are not wanting to come out in one piece.
2005 B5.5, TD Tuning, R783s, GTB2260VK, 6 speed O1E, BSM 2/09, Pod w/ 40 PSI & EGT Gauge, Thor Skid Plate, Cat FF, Euro switch
1996
B4V, 2.0L w/ BHW pistons, Rosten Rods, Girdle, 11mm, GTB1756vk, RC6, PP764s, .622 5th, Colt Cam II, Ecodes W/leveling motors & Euro switch, fog lights, Koni Yellow, Cat FF, Whitbread 2.5" DP, exhaust, FMIC
Sprocket is offline   Reply With Quote
Old March 19th, 2018, 05:46   #36
oilhammer's Avatar
Don't bother. The replacements won't really fit the same, and you'll get pissed you paid so much for a little disc of plastic. They really don't even look exactly the same as what comes out, either.
I use Flex Tape (like the guy on TV sells). You can find it in stores easily enough. Just cut small pieces to fit down in where they need to go to cover the holes. Works great.
Page generated in 0.12060 seconds with 12 queries
[Output: 73.90 Kb. compressed to 64.37 Kb. by saving 9.53 Kb. (12.89%)]
