DarrenUK
I have been thinking about ways of assessing how well our choosen fuel is combusting.
Using VAG-COM and looking at measuring blocks group 013 you get 'idle speed smooth running control'. This shows the ECU modifying fuelling to each cylinder to balance combustion - the ECU measures the time it takes for a magnetic trigger on the flywheel to pass a sensor. If a given cylinders combustion event pushes the flywheel faster the ECU reduces fuelling.
I think I'm right in saying A3/B4 models show three values
1st is comparison of cyl 3 and 4
2nd cyl 2 and 3
3rd cyl 1 and 3
A4 models (what I've got) show a value for each cylinder
From taking and graphing a few logs of my vehicle it appears the values for cyl 1 and 4 mirror each other as do 2 and 3..... Both of these 'mirrors' have a different offset from zero which appears to change slightly over time.....
this block has specified values at warm engine idle for my engine between -2 and 2
Bosch state that
Excessively high values point to a low compression or contaminated injectors.
Low values to high compression or leaking injectors.
Anyway my thinking is that if my fuel is not burning well and I activate the glow plugs combustion should improve.....
If I activate one glow plug I should be able to see the difference using block 013.
A quick test running on diesel after a coldish start (I had run the car a few hours before this) showed the post glow running for three minutes with a coolant temp of 15deg C. glow plug bits show 10110000 when after glowing or 11010000 if rpm is above 2500
I then used a jumper from the battery to glow plug 4 and noticed the 0.47 - 0.49 value fall to 0.45 - 0.47 untill I removed the lead when it rose back to 0.47 - 0.49
Of course it is possible to log these values when not at idle....
I am going to do some more experimenting with this and different fuels. I will post my results.
If anyone else tries this I would be interested to hear results.
Also I searched on tdiclub and did not find much about using this potentially usefull measuring block.
I had previously found it being used under full throttle acceleration to tune timing for performance in a 1.8tubo SI engine -
http://www.revotechnik.com/products/pdf/SelectPlus_AdvancedUserGuide_V0707.pdf
Keeping an eye on this data set should be useful for an early warning of failing injectors or gumming rings.
Best
Darren
2nd cyl 2 and 3
3rd cyl 1 and 3
Bosch state that
Best
Darren
