AndyBees
- Joined
- May 27, 2003
- Location
- Southeast Kentucky
- TDI
- Silver 2003 Jetta TDI, Silver 2000 Jetta TDI (sold), '84 Vanagon with '02 ALH engine
Update
Update EDIT: 1/20/19, This exhaust hanging set-up was a disaster as David H alluded to in his comments. After many disappointments, I completely replaced it with a SS set-up from the Turbo out to the CAT as set-up here. It has a swivel donut and hangs on two rubber mounts. I also used the quick connect joints. The new SS system is awesome.
Yesterday, I spent most of the day working with the wiring on the left side back to the InterCooler area. Refer to the pics above. I modified and re-bundled the main OE Vanagon tail light wiring assembly as well as custom mounted it a little lower (no pics right now). Also, I cut and lengthened the left tail light wire/plug to accomodate the Plexiglas.
Today, I basically finished the exhaust system mounting. As you may recall, the earlier attempt fabricating the exhaust system was not satisfactory. Anyway, I did a re-make a few weeks ago but just now got around to mounting it. I moved the CAT more to the right (looking from the rear). That move will allow me to install the Vanagon style oil filler pipe on the oil pan (access thru the license plate hole). Also, the move sure limited me on the muffler......as the pics will show.
Comments are at the top of each photo!
Okay, as you know, the exhaust system must be mounted to the engine (do not hang anything off the body or frame). That was the challenge considering how I modified the Down-pipe (see previous posts earlier in this Thread).
The pic below shows the right side exhaust mounting tube (support brace, 3/4" square tube) bolted to the Engine motor mount bracket near the motor mount. Although this approach does seem quite stiff and secure, I do plan to add a brace down from the engine accessory bracket.
The pic below shows the exhaust support brace bolted to the top of the CAT. Although it looks to be drooping or sagging, it is not. That is basically the angle of the support brace.
Below is another shot from a distance.
The pic below shows the mounting hanger on the left rear corner of the engine. I do plan to trim off the extra metal sticking out there. I wanted 2" pipe, but the dude did the fabrication using 1 7/8". So, it will have to do for now.........something to change in the future! I do plan to fabricate and install a heat shield to protect the Turbo Actuator.
The pic below shows the exhaust as it crosses from left to right at the rear of the engine. You can see that the exhaust is slightly higher than the oil pan except for the CAT.
This next pic is a little farther to the right. You can see one of the mis-haps to this old Vanagon.....just surface rust due to a bump. And, that's my Schnauzer (Scruff)....needs a hair cut and shave!
The pic below shows the end of the muffler and a very short exhaust pipe....may add one of those chrome thingys on the end. Notice the up-swing of the body gives an appearance that the pipe/muffler is drooping....not so! At a distance, looking at the "whole thing" it looks pretty good~!
Looking down the barrel of the muffler.
This is another pic looking down the barrel of the muffler from another angle. You can see the bottom of the system is roughly level with the oil pan.
The pic below sort of puts the exhaust system in perspective relative to the rear end of the Vanagon.........
Although the system appears in these pics to be a little low, it is actually about the same level of the OE system with the gasser engine. Other than one section of pipe being 1 7/8 inch, I'm pretty well pleased with how it turned out.
