Old April 7th, 2017, 19:09   #1
inthered
TDI(s): 2013 Passat
Fuel Economy: 47 mpg
Default My 2013 Passat burned 4 quarts in 12,000 miles?
Yesterday I got a low oil pressure warning. I checked my dipstick and it was beyond low. I do not have a place to change my own oil so I've been going to the dealership for $60 all said and done every change and I went first thing today.
Dealership gave the car a good look and said no leaks or drips anywhere or evidence of that. I was told to adhere to the 10,000 mile schedule and as the car gets older it will consume oil which is normal.
My car has 113,000 on it. I don't buy that explanation. What I think happened was 505.01 wasn't used last time and the car ate it over the past three months. I've never had anything close to this ever happen before. Also, I never saw or smelled any type of smoke or burning oil.
So what do you guys think? Am I crazy or is it possible?
inthered is offline   Reply With Quote
Old April 7th, 2017, 19:46   #2
tdiatlast
I can't understand how a sump full of 505.01 oil would burn any quicker than any other oil.
Unless there was a catastrophic loss of oil, I don't understand how you wouldn't notice the gradual loss of oil. As any engine ages, it's a good idea to check the oil more frequently...getting 600 miles per tank of diesel fuel, probably every fill-up would be a good idea.
2014 Passat TDI SEL DSG (returned 12/14/16)
2009 JSW TDI DSG (returned 12/15/16)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
tdiatlast is offline   Reply With Quote
Old April 7th, 2017, 19:54   #3
tdi54
If it has just happened at your last oil change, one could suspect whether it was filled with proper oil. Has it consumed any oil prior to the last oil change?
tdi54 is offline   Reply With Quote
Old April 7th, 2017, 20:08   #4
turbobrick240
turbobrick240's Avatar
Good chance the turbo is passing oil. Not good to let it get so low that oil pressure is lost.
Old April 7th, 2017, 21:44   #5
whitedog
505.01 in a 2013 Passat?
Can fold paper in half eight times.
Old April 8th, 2017, 04:20   #6
inthered
TDI(s): 2013 Passat
I haven't done the oil changes myself since I had the 05 Jetta. I remember 505.01 as the spec. I don't remember the new spec off hand. I did a quick search and saw it. Is it .03 or .05 now?
I never had any oil loss before. Certainly nothing noticeable. Just trying to think it through.
I know you needed oil of a certain spec. So nothing would happen if you threw in oil off the shelf from Walmart? There must be some consequence to that?
Old April 8th, 2017, 08:05   #7
turbobrick240
The correct oil spec. is 507. Using the wrong oil can result in faster filling of the dpf with oil ash, and worse depending on the oil used. If you're not married to keeping the dpf, any cj4/ck4 5w40 works well.
Old April 8th, 2017, 09:23   #8
inthered
TDI(s): 2013 Passat
Thanks, turbo.
I plan to keep things as they are. I think the regenerations happened more often as of late, but I'm not sure. I don't keep track of the frequency but I thought it seemed to be more.
My typical week is comprised mostly of my 70-72 miles each ah commute to work so I go through about a tank a week. I'll be paying more attention now but I was super surprised to see this issue.
Old April 10th, 2017, 11:02   #9
Rico567
Originally Posted by inthered View Post
I haven't done the oil changes myself since I had the 05 Jetta. I remember 505.01 as the spec. I don't remember the new spec off hand. I did a quick search and saw it. Is it .03 or .05 now? <snip>
A 2013 Passat TDI takes 507.00 oil, which is what I put in ours. I've always just used the Castrol, because the local dealer sells it for a reasonable price. We've got almost 57K on ours, and it's never used a drop.
"I reject your reality and substitute my own."
- Adam Savage
Rico567 is offline   Reply With Quote
Old April 11th, 2017, 10:39   #10
jjblbi
Fuel Economy: 45 mpg S, 42 mpg W
I also commute ~70 miles each way daily. My '14 Passat has a little over 116k miles on it now. I change the oil every 10k miles and use a pint or less of oil between changes. Don't tell anyone, I am using Delvac-1 5w-40. 43 mpg average at weekly fill-ups, DSG.
jjblbi is offline   Reply With Quote
Old April 12th, 2017, 04:28   #11
eb2143
eb2143's Avatar
TDI(s): None
Or if it was filled in the first place... Has happened before. You should know the answer in the next 1000 milesif you monitor oil level.
Do the new passats only have oil pressure sensor... No sensor for oil level?
SOLD MY BABY: 2001 Jetta TDI 5mt, Bosio Sprint 520s, Koni FSDs, VW HD Springs, 10mm spacer, Audi TT LCA bushings, 034 motorsports strut mounts, E-code lights, Audi TT "short"-shifter, IDparts rear sway bar, DG Panzer plate, Caterpillar 2m fuel filter, Frostheater, GLI Recaros, GTI 3-spoke steering wheel, Audi S3 shifter, R-line stainless pedals[/URL]
eb2143 is offline   Reply With Quote
Old April 19th, 2017, 10:05   #12
Nevada_TDI
After reading through this thread, I am thinking the stealership did not re-fill the engine oil after draining it. In order to be "using" that much oil it would/should be obvious somewhere, like out the tail pipe. Have you double checked the drain plug on the pan; if it was that you be parking over a puddle all the time. I am glad to hear you caught it as soon as you did.
_______________
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, TDTuning, HIFLO .216's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Previous Diesel: 1983 Rabbit Diesel
Nevada_TDI is offline   Reply With Quote
Old April 19th, 2017, 10:15   #13
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
I would verify the possible oil consumption before jumping to any conclusions.
The CKRA engine is not known for using any concerning amount of oil between services, even the "acceptable" level VAG allows.
oilhammer
www.cardocautomotive.com
Old April 20th, 2017, 06:00   #14
adjat84th
adjat84th's Avatar
Not sure about the CKRA, but the EA288s (2015+) do have a level/temp combined sensor in the pan.
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTD1752vrk, 4bar MAP, CP3, Peloquin LSD, DC stage 3 w/ SMF, Fluidampr
Old April 20th, 2017, 06:30   #15
tdiatlast
...there's just no way 4 qts. could disappear w/o additional issues...
Now I'm wondering if a moderator should delete this entire thread, to keep the potential of misinformation from spreading on the internet. The title is rather hysterical, isn't it????
2012-2013 Passat Turbocharger Warranty Extended to 10 years/120,000 Miles! cevans VW Passat Family (NMS and B7) TDIs (2012+) 147 July 28th, 2014 14:34
New 2013... 1/2 quart oil burned at 1200 miles nullsignature VW MKVI-A6 Jetta Sedan (~ 2011+) 32 July 26th, 2013 18:00
Recap: 12 Months and 39,000 miles on a used Passat wagon s4phillips VW B5 Passat TDIs 4 November 22nd, 2009 17:13
Burned Out Glow Plug at 9,000 Miles PDJetta VW MKIV-A4 TDIs (VE and PD) 13 June 28th, 2004 12:15
30,000 miles on 5 quarts overfill (1/2 qt. dirty) a problem? Rus VW MKIV-A4 TDIs (VE and PD) 7 August 8th, 2001 10:32
Page generated in 0.17074 seconds with 11 queries
[Output: 127.87 Kb. compressed to 106.51 Kb. by saving 21.36 Kb. (16.71%)]
