I also apologize for not putting more details. But I did not think that the answer had so many variants because of so much ... But sometimes it is very difficult to expose our ideas in a simple Post, moreover in a language that is not mine that I use in technical words.
Thank you also for the things you wrote me !!!
But if understood correctly, the car having the air filter having muffler will spool later. right?
But did not realize why, if the car lighter and with a shorter transmission ratio will spool later !? Should not it be sooner? I wanted to mount the PD engine in a Golf MK2 or a Seat Ibiza 6K2 because it would be lighter ... But now I was confused with what you said ...
The idea is to make a car to make 0-400 0-800 and something like 0-2Km (something like 0-1 / 4 of mile 0.5 miles and something like 1 mile).
In Portugal devoting a car to Drag is very difficult, because we have some very good companies here in the increase of performance. It is no wonder that the European Record of drag 0-1 / 4 miles is Portuguese (9.60 seconds), so it is very difficult to compete with these results.
So I really enjoyed doing an excellent project to at least do a good race street car. I intend to do everything along this current year, the base will be an ARL engine, with porting in the head. an excellent Camshaft I do not know yet which but I thought of something of 300º and 10.25 of Lift ... something really show !!! reinforced valve springs, also do not know which, but the idea will be to make the maximum rpm possible. Then the turbo is the foundation piece of this setup, with a 76mm Donwpipe and remaining exhaust line at 70mm, a large intercooler maybe the entire front of the car. And in the injection I still do not know if Firad + 160% or Dssr + 180% but something around it !!! and of course an excellent ecu map ...
Afterwards want Water-Methanol and Nitro but only later.
I wanted to reach the target of + 400hp WITHOUT nitro!!!
I wanted to do 6500 rpm (I know the PD engine is a lot, but why is that?) What's the reason it will not handle 6500rmp?
Why PD engines do not do 6500rpm's but the VP do?
This is a targets, trying to make the maximum RPM possible in PD I know it will be something around 5500, but I wanted to go beyond ...
All help, and opinions are welcome...
