For some reason the back of my engine is full of oil dripping all the way down to the drive axles.
I'm loosing enough oil between oil changes, that it goes from just at the right top limit to below the bottom limit between oil changes. How quick, I don't know for sure - because i've just started paying attention to it - it might be worse than leaking that much in 10k miles - but i'm thinking oil cap leak is definitely to blame for at least some of the oil on the back of the engine - if not all.
This engine cover i cleaned at the last oil change (removed the previous oil splash on it) and it was not oily at all after i replaced the oil last. And now - after 10k miles ... it's back and my oil level went down also going down also.
This is the top of the valve cover that allows the cap to screw into.
In this picture you'll see that the leak seems even above the exhaust header mounting screws.
I tried a close-up of the area behind the oil cap above the headers
I'm thinking maybe this cap should have some type of rubber seal? It does screw relatively tight, but i can't understand how metal on metal is suppose to make a oil proof seal. No wonder it's leaking.
On the other hand i can't seem to find where the rubber seal would go or where it would be missing from.
Anyway - let me know what you think
