ALH rabbit truck swap
oldpoopie
Portland Oregon
2001 golf gl, 2006 jetta, 1981 ALH swapped rabbit pickup, 1998 beetle
A buddy is hooking me up with a pretty nice rabbit truck.
Its already has been modified to run an O2J trans and clutch setup. All i had to get was a pass side motor mount.
The engine is at the machine shop now, it will be an alh, 11mm pump, R520 or pp764 (not sure yet) 17/22 turbo.
02j mk4 trans with taller 5th gear and peloquin diff.
Im planning on running the mk4 cluster, so i spent the past 3 evenings ripping apart the interior mk4 dash harness. This is whats left before final cleanup.
Also picked up this sprinter intercooler for it. (guess what, it wont fit! Went with an Air-Water setup instead)
papasmurf
Orlando
1997 jetta tdi, 2004 passat sedan tdi, 2005 passat wagon tdi , 2005 passat sedan tdi
Awesome. I can't wait to see this truck transform
sccaddy
South Carolina
96TDI Passat, 1.6 81d caddy, 86d golf, 82d rabbit, 81ALH caddy, 82 Westy
What 5th gear are you going with on the O2J? Just refresh motor? or you going to bore it out bigger for oversize pistons? Nice intercooler. I also have a caddy in that same color.
[/URL][/IMG]
oldpoopie
Portland Oregon
Nice looking truck!
The 02j came from my golf. Its got a peloquin and a .658 5th already installed.
Block is being bored out for oversize ASV pistons and rosten rods. Head is ported with a stage 2 colt cam. r520 injectors, 11mm pump.
Turbo will either be gtb2260vk or 17/22 not sure yet.
tothemax
Nevada
TDIs: 2003 Jetta, 2016 Q5 3.0
That will be a FAAAAAAAAAAST caddy.. .cant wait to see it J...
burpod
teh stallionz!!1
cape cod, ma
82 rabbit vnt ahu, 98 jetta vnt ahu, 05 parts car, 88 scirocco.. :/
when i do my scirocco i'm going to do a 2056vl i think. 17/22 is fun and very responsive, but i certainly wouldn't mind a little more. responsiveness shouldn't be an issue either way i think, given the weight.
oldpoopie
Portland Oregon
sccaddy
South Carolina
What intake are you planning on using? Are you keeping the power steering and A/C?
whitedog
Bend, Oregon
Interesting. Today Cousin Louise told me a friend of hers is looking to do this. Would an AHU be any easier?
whitedog
Bend, Oregon
Belt side mount:
(not ALH unless you change the timing belt idler design. it WILL bolt up to the block and be in the correct possition, the idler is just in the way)
burpod
teh stallionz!!1
cape cod, ma
have you checked out epytec ?
i have a set of NLS mounts in my rabbit. but they are way overpriced for what they are....
in my rabbit, i just rigged up a ~1980 honda civic clutch cable and the 02b ? eurovan lever i bought a while back from 1stvw. works great. just had to make a little bracket with my drill and grinder
oldpoopie
Portland Oregon
Yes, AHU is easier to bolt in, but i already have an ALH.
As for the belt side mount, the lower idler roller will be eliminated, and a larger non-automatic tensioner will be used.
Intake will likely be a PD130 gearbox-side inlet manifold sourced from RyanP at darkside.
The truck is non-power steering, non-AC so those will be deleted.
Best example of what I'm trying to do is MrDave's build.
http://forums.vwvortex.com/showthread.php?778864-The-Rabbit-TDI-Project-Part-1-Introduction
oldpoopie
Portland Oregon
@burpod,
The truck is coming to me already converted to run the O2J, so shift linkage, cables, and motor mounts come with also, so I didn't have to go hunting for any of it. :) thanks for the link though! Cool stuff there!
Im also putting in the gokraut front crossmember reinforcement bar.
burpod
teh stallionz!!1
cape cod, ma
thats a nice bar, i got one a little while back while they were on sale, as well as the X subframe bar - highly recommend that piece to really tighten things up
oldpoopie
Portland Oregon
Yes, I plan on getting the x bar but want to get it running first
vw_nut
Beechgrove, TN, 37018
, 1981 VW pickup TDI Conversion, , 2000 Golf TDI,1985 Cabriolet 16V,2006 jetta
Not having A/C makes it much easier and a lot more room for the intercooler, no need for air in your neck oof the woods here in TN it's a must for me, I'm in the process of fixing a few things while my motor is out
oldpoopie
Portland Oregon
Managed to score a cabriolet pedal cluster today so i can run cruise control.
Have to go back and grab the stalk parts.
Also picked up the block from being bored and the head from being freshened up. :)
Ill assemble the motor and measure for protrusion, then dissasemble and have it decked.
vw_nut
Are you gonna run cable or hydraulic clutch, mk4 hyd clutch is really nice and very easy to do
burpod
teh stallionz!!1
cape cod, ma
fwiw, it's really easy to make your own mounting bracket/holes for those switches on the stock mk1 pedal cluster. that's why i did, everything works perfect and was easy to do with simple hand tools
vw_nut
Well I have arthritis in my knee and its soo nice to have the hydraulic clutch effortless to use
turbodan62
Orange, CA
2005 Jetta TDI, Rabit TDI
i called NLS and they did not know which manual belt tensioner to use .... i think it would be a 16 valve because the belt is wider .. did you ever order and get the right one ?? Thanks Tdan
oldpoopie
Portland Oregon
Ok I'm fairly sure it is the 16v tensioner part # 051109243. Im ordering one to see.
