SmilesAndGimps
Last month I replaced the clutch on my 2002 Jetta after the bearing went out. New clutch kit as well as bearing, fork, shaft and clip. Ran great for maybe two weeks then started acting funny, a little rough engaging in first gear and sometimes rough switching between gears until one day I was backing out of the driveway and it died, stuck in reverse.
So I figured it was the slave cylinder and replaced that this week. Just bled the air out this morning and tried to drive. Starting in neutral it turns on but I can't shift it into any gears. Starting it in first gear with the clutch pedal depressed works and it will drive forward and shift through gears just fine. Then I tried to back out and the pedal got a little soft then the car died, stuck in gear again.
So I plan to reprime the slave cylinder to make sure all the air is out and if that doesn't solve it I'll move on the replacing the master cylinder I suppose. Just want to make sure I'm not missing something here, anyone ever had similar issues who can tell me I'm on the right track? Thanks!
