Baxter'sTDI
Long story short, my wife and I took our Jetta about five hours from home to get some help with a timing belt replacement. After we had replaced it, I started the car and it ran great. Driving around, warming it up, the oil light came on and started flashing. The car has a decent oil leak so it was nothing new so I jumped out and checked the oil, which was fine, but I added a little just to be safe. Well the oil light kept flashing. On my way back from warming it up the belt must have skipped at least one tooth on the cam and who knows how many on the injection pump due to lack of tension and started running like crap. We got the car back and the next morning lined everything up, put more tension on the belt and got it running great, but the oil light kept coming on. We decided the sensor must be going bad or some wires were wiggled loose or what-have-you and went on our way. About 2.5 hours into our trip on the interstate the engine started making all kinds of racket. We made it into a gas station parking lot where it finally died and wouldn't even crank, which I figured it had probably locked up. Well we started tearing it apart last night and here's what we found when we pulled the pan. Sorry for the crappy pics.
That's the number four cylinder connecting rod bearings, cap, and bolts laying in the pan. This is where it started getting interesting. One bolt was broken in half, one half being in the cap, the other still in the rod. The other bolt, however, was laying in almost perfect shape in the pan all by itself. I have suspicions but want to know what you guys think about that.
This one is kinda hard to see but it's the connecting rod, off the crank, wedged between the crank and the block which was preventing it from rotating. Rotating the crank freed it up, making evident it wasn't locked up.
And the rod...
Surprisingly, the cylinder and piston look fine. I am worried about the head though, with all that slop going on. What do you guys think? Would I be able to see damage? I am going to have it pressure tested at the very least, maybe pull apart depending on what you guys say.
So. What do you guys think? Please feel free to give me any advice on what I need to check or do. I am probably going to get a lower mileage block and rotating assembly from a member on here for less than what it would cost to repair mine.
And the rod...
