Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI News/Tech
TDI News/Tech This Forum is for the posting of TDI news related items.
Old November 8th, 2019, 12:49   #16
kjclow
Fuel Economy: 55 max / 44 avg on beetle ~37 on JSW
Not saying it won't work but it almost sounds like the hype of the 100 mpg carbs.
2010 silver/black JSW TDI with DSG, 2017 Ram 1500 EcoDiesel
kjclow is offline   Reply With Quote
Old November 8th, 2019, 13:15   #17
Lightflyer1
Lightflyer1's Avatar
Did that hype come from Sandia National Labs?
It should give the emissions a much much easier job. With soot being reduced 50-100% and NOx dropping a lot as well, they would have to work a lot less. DPF regens at 1k mile increments instead of 200 miles?
Old November 21st, 2019, 10:29   #18
woofie2
woofie2's Avatar
Fuel Economy: 25/22/23
With Sandia's research aimed at larger diesel engines, I suspect applications in shipping, generators and locomotive systems as their money point. it will take Bosio or someone to build a smaller engine injector on this design.
Likely 2-3 years until anyone goes to mass production on the new injectors, my guess is that there will need to be some redesign on engines from CAT, GE, Bosch, etc to incorporate this new injector.
Traitor went to a RAM
Fuelly link
woofie2 is offline   Reply With Quote
Old November 21st, 2019, 10:40   #19
alext91
alext91's Avatar
Wow, Drummond Biles was one of my TAs in college! Really cool to see his name on this!
Sent from my SM-G960U using Tapatalk
2013 Jetta Sportwagen TDI 6MT Pano, Candy White
2015 Golf TDI S 4DR 6MT (Wife's)
2015 Yamaha FJ-09
1999.5 Jetta TDI Tornado Red (Sold)
1996 Yamaha FZR 600 (Sold)
alext91 is offline   Reply With Quote
Old November 26th, 2019, 10:14   #20
SilverGhost
SilverGhost's Avatar
Well, the piston bowl is mainly there to work with injector spray to promote fuel/air mixing. The ducted injector removes this need. Without the bowl the piston can stop further from head or head can have a pocket.
Not an easy retrofit, but 'simple' change during design stage.
Jason
SilverGhost is offline   Reply With Quote
Old November 26th, 2019, 12:11   #21
casioqv
I think the TDI or other small direct injection engines should be simple to retrofit in this manner, by putting the ducts inside the existing piston bowl. It would essentially be just a new injector nozzle with an extra part, that will require removal of the head. The new nozzles will have six machined jets instead of a circular spray, and exposed threads on the bottom. After installing the injectors with the head removed, you could screw on a fan shaped six-way duct designed to fit neatly into the stock bowl.
Further improvements could be had with an entirely new piston, machined in a 'starburst' pattern to have a spot for each duct.
Overall it's pretty shocking that something this simple works so much better than the highly optimized current approach.
2009 Touareg 3.0 TDI
casioqv is offline   Reply With Quote
Old November 28th, 2019, 18:37   #22
GoFaster
Moderator at Large
For sure any proposed modification like this would have to be designed in tandem with revising the shape of the piston top. The trouble on smaller engines is that the injector is surrounded by valves (and a glow plug tip) and there is not much real estate to work with.
The photo in the opening shot of the article shows this device in somebody's fingertips ... the whole deal looks to be (guess) 20mm across, and looks really intricate ... those socket-head screws are really really small. But there isn't that much real estate available on an automotive cylinder head. It would have to be even smaller.
Unless ... you re-think the way the injector sprays, and build something that achieves this function directly into the cylinder head itself.
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
Old November 30th, 2019, 14:35   #23
DPM
Fuel Economy: 38.5- 47 Forester, Citroen 55- 63
I'm wondering if you could build it into the injector- instead of minimising the tip of the nozzle, give it lots of mass then "core" a ring out axially and drill a larger outer hole and then the smaller EDM'd injection hole concentrically for each hole..
DPM is online now   Reply With Quote
Old December 1st, 2019, 06:35   #24
Dannyboy
TDI(s): 2014
I remember seeing the paper on this back in 2017, interesting read but like what Go-faster said it's going to be difficult to engineer a duct into a relatively small area that will effectively work, going to have to completely redesign the head and piston bowl to accommodate it. With electrification rolling out at VW , no point spending money on something that's going to be obsolete in the near future. If VW wasn't caught with their pants down back in 2015 , they very well may have had the time and money to develop this. They are beginning to distance themselves from diesel now
Dannyboy is offline   Reply With Quote
Old December 16th, 2019, 16:19   #25
QuickTD
Anybody remember pre-chambers? For something like this to survive in the severe heat and oxidising environment of a modern diesel, it will require cooling and need to be made from inconel. The whole thing will need to be buried in the head, like a pre-chamber, to properly cool. As a result, it will suffer the same high surface area heat loss (efficiency and starting problems) as a pre-chamber. Nice idea and probably works well in a low specific output test engine. I just can't see it working out in real life.
QuickTD is offline   Reply With Quote
Old December 17th, 2019, 09:57   #26
woofie2
woofie2's Avatar
Refashioning the injector nozzle for smaller engines will be tough, pictured looks like it would be for a very large engine, (power plant, shipping boat, something large!) places where a retrofit would be a better idea than replacement of the head.
Second phase would be motors for truck freight, likely a head redesign with multiple injectors? a place where it is easier to test and redesign.
Then maybe they look at smaller than 5L engines....
If you look at in dollars, the bigger engines need more improvements, they flat burn more fuel.
https://www.worldmaritimeaffairs.com...rtsila-sulzer/
Where a 10% gain means 1000's of dollars a month or in a semi truck is $300 a month vs a 10% gain in a half ton, 3/4 ton or 1 ton pickup is $20
Fuelly link
Old December 17th, 2019, 10:38   #27
nicklockard
Torque Dorque
nicklockard's Avatar
Fuel Economy: 25.5, combined
I can definitely see this retrofittable to cargo ship diesel engines, trains, and large generators. A second generation could possibly retrofit to HD diesel OTR engines and if the specific application warranted the investment and trials.
nicklockard is offline   Reply With Quote
Old December 17th, 2019, 13:48   #28
woofie2
woofie2's Avatar
Someone like Bosio would need to view and tweak their design to be closer to the larger nozzle, but making micron sized holes is a very small process.
Fuelly link
Old December 17th, 2019, 18:39   #29
nicklockard
Torque Dorque
Perhaps they can, but I suspect that there are at least these two critical design criteria:
1. Minimum annular gap size needed to support sufficient air mass and velocity, paired with
2. Annular gap width (AGW) to Orifice size ratio (AGW/OS)
And it's probable dependent on shape of discharge cone, pressure drops, and maybe a few other things. There are probably 625 ways to get it wrong and 2 ways to get it right.
The only way I see an aftermarket supplier succeeding at it is by partnering with SNL and buying rights to the IP.
But it would be insanely cool if they were up for the challenge! Imagine the tuning possibilities it would open up.
Old December 17th, 2019, 19:50   #30
Lightflyer1
That is why I thought VW might make a good partner in this due to all the stink over dieselgate and all. Being able to pull themselves out of the fire by partnering with SNL and cleaning up their emissions would give them a little better standing. Besides the billions of dollars they fined VW ought to go to some purpose like this instead of crushing cars. But I am just a consumer, what do I know?
BorgWarner develops new turbocharger to help reduce diesel emissions buckeye96 TDI News/Tech 12 July 10th, 2008 11:04
B20- ULSD cut emissions greatly NHTDI Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 1 January 9th, 2005 06:39
OT: Ford develops backup plan for diesel emissions dilt1 TDI News/Tech 4 December 16th, 2002 08:57
Enviro Cat Reduces diesel emissions... Gary Miyakawa VW MKIV-A4 TDIs (VE and PD) 1 January 13th, 2000 04:22
Page generated in 0.18004 seconds with 11 queries
[Output: 132.11 Kb. compressed to 110.71 Kb. by saving 21.40 Kb. (16.20%)]
