Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI News/Tech
TDI News/Tech This Forum is for the posting of TDI news related items.
Old June 24th, 2008, 05:58   #1
buckeye96
TDI(s): 2005 Jetta ?
Default BorgWarner develops new turbocharger to help reduce diesel emissions
http://www.autobloggreen.com/2008/06...-diesel-emiss/
BorgWarner has developed a new turbocharger design that it claims will help reduce diesel emissions. One of the methods used to reduce emissions of nitrogen oxides from diesel engines is to recirculate some of the exhaust gases (EGR). Low pressure EGR helps to reduce the combustion temperatures and thus the production of NOx. However injecting the exhaust gases upstream of the turbo compressor has caused problems in the past as the exhaust particles and high temperature of the exhaust have caused metal fatigue. Downstream injection requires higher pressures. BorgWarner has developed new materials and coatings that can better withstand low pressure EGR and resist particulate deposits on the compressor wheels. Two European manufacturers are expected to introduce the new turbochargers on their U.S. diesel engines in 2008. Volkswagen, BMW and Mercedes Benz are introducing new clean diesels this year.
buckeye96 is offline   Reply With Quote
Old June 24th, 2008, 17:33   #2
bikegeek
bikegeek's Avatar
Good article...thanks!
Original owner of a 2000 GLS 5-speed 102k, ventectomy, panzer full metal jacket
bikegeek is offline   Reply With Quote
Old June 24th, 2008, 19:05   #3
oscarmv
Originally Posted by drwho
This is all nice and everything, but I want to hear more about improving economy on diesels. Seems like a lot of sacrifices have been made in economy on some diesels for all of these new emission devices. The 6.4 Ford Powerstroke and the 6.7 Cummins diesel both have less fuel economy than the previous engines due to the extra emissions. That sophisticated exhaust on the new Jetta is probably why the economy ratings are so dismal.
Note that the dismal economy ratings for the new clean TDI are about the same as the dismal economy ratings for the previous 1.9 TDI with the new EPA testing procedure.
Still, it's nice to see with all the people sounding the alarm bells that gasoline engines will soon be the bees knees that the oil burner engineers don't stand still.
oscarmv is offline   Reply With Quote
Old June 25th, 2008, 12:15   #4
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Fuel Economy: 116 mpg(e), 36 mpg gas, 100 mpg combined
Originally Posted by buckeye96
...However injecting the exhaust gases upstream of the turbo compressor has caused problems in the past as the exhaust particles and high temperature of the exhaust have caused metal fatigue.
Their remedy to high particulates and high temperature is different turbocharger materials? Why aren't the causes being addressed instead of the resultant effect?
Seems simple enough to me, reduce the particulate and reduce the temperature by using Biodiesel.
Svante Arrhenius 1896
Old June 25th, 2008, 17:18   #5
TurbinePower
TDI(s): None
It's probably in conjunction with DPF technology for the particulate handling capacity. Combine some materials that can handle a bit more abrasive particles than standard filtered air has with the ability to withstand higher heats... I can see it.
Still with you on that last part, though.
Originally Posted by FL2AK-tdi
I just wish that it would stop breaking. If I could go one OCI without something breaking, I would be a huge VW fan lol.
Small stable of VWs (projects)...
'80 Dasher Diesel, full restoration in the slow burner works
'82 Quantum "Coupe" 1.6 CIS gas power, daily driver
'89 Fox wagon (Korva!), the new back porch project. Suspension and interior work in progress!
TurbinePower is offline   Reply With Quote
Old June 26th, 2008, 07:50   #6
JamesBa
TDI(s): GOLF '02
I read articles like these and laugh. Technology for better diesel engines is already available. It's just a question of getting some manufacturer to apply it.
'02 GOLF TDI
JamesBa is offline   Reply With Quote
Old June 26th, 2008, 09:14   #7
KILOFINAL
Default dismal economy ratings on the 1.9L TDI??????
Hello McFly???.......I'm getting 1300KM on a tank of diesel.
2006 JETTA TDI
280,000
Burlington
KILOFINAL is offline   Reply With Quote
Old June 26th, 2008, 16:33   #8
EddyKilowatt
EddyKilowatt's Avatar
Um, controlled auto-ignition... is that a variation on the glow plug concept?
2003 Golf GL, 5-speed. Bosio .205 injectors, balanced by DbW. Mobil ESP 5W-30 oil.
EddyKilowatt is offline   Reply With Quote
Old June 27th, 2008, 05:42   #9
JamesBa
TDI(s): GOLF '02
Default controlled auto-ignition
Hey, if it works better, that's all I care about.
'02 GOLF TDI
Old June 28th, 2008, 09:19   #10
DieselDub
you thought intake manifold coking was irritating, now it's going to jam up the intercooler!
DieselDub is offline   Reply With Quote
Old July 10th, 2008, 10:35   #11
Ski in NC
Fuel Economy: 48-52 typical
I don't get it. Why not take egr supply from downstream of DPF? Then no particulates go into turbo, intercooler and engine. If heat is a problem, run it through a cooler before mixing with inlet air.
This must be for non-DPF engines, which does not apply to VW's. -Eric
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
Old July 10th, 2008, 10:43   #12
linewarbr
linewarbr's Avatar
Originally Posted by micky0604
Great!--------------------------------------------------------This is really fantastic.I have never seen such a good thing.You may be a genius.I am honoured to appreciate the excellent work.Feel very excited.warcraft power leveling warcraft power leveling world of warcraft power leveling wow power leveling wow powerleveling---------------------------------------------------------You will make a brilliant achievement!!!
What in the heck is all of this foolishness here?
In this war of lines, so many have been crossed. Where will it all stop?
2007 Jeep Grand Cherokee CRD (mine)
2014 Passat TDI SE DSG (wife's, bought back Feb 2017)
linewarbr is offline   Reply With Quote
Old July 10th, 2008, 11:04   #13
jvance
Comment spam. Can we get an IP ban here?
jvance is offline   Reply With Quote
Page generated in 0.17858 seconds with 10 queries
[Output: 111.52 Kb. compressed to 92.96 Kb. by saving 18.56 Kb. (16.64%)]
