tongsli
Hey Deejaaa,
Can you power up those angel eyes and take a picture?
So what bulb do they use?Just got a PM from Jeff, no V2 H1s available for the Golf. Projectors are to big.
they feel good too. has a little heft to it with the glass.I'm itching for a set damn they look good
bajan 4g
i didnt ask for the angels to work so not sure how to do that. i've seen pics and they are bright.Hey Deejaaa,
Thanks for the clarification. Do you have any photos of the Golf headlights with the projectors?I messed up when I posted the info about the new Jetta headlights yesterday. The ratio of Jetta to Golf lights I sell is rather high, so my head was thinking all about the Jetta when I posted.
To clarify, the 2.0 lights and their new projectors are for the Jetta only. The Golf headlight assemblies are not big enough to fit the projectors. So the Golf lights will remain with their original projectors. The Golf projectors take a modified bulb that is spicific to the projector itself. That being said, there are plenty of places to get bulb replacements. The bulb fits the G1, G3, and G8 projectors. You can find them on many website, ebay, amazon, etc. Here is an example.
I might be looking at the pictures wrong, but are the projectors mounted in front of the old reflectors?Here are photos of the first Golf set I made. When I make them now, I actually widen the mounting hole for them so that the projectors sit back farther in the housing and aren't as close to the lens, but the overall look is the same.
Assuming you don't have a Euro switch and you haven't disabled your DRL's with a stock light switch:With the standard (as is in the installation instructions) wiring, for the Golf with Angel Eyes, which lights turn on when?
Sitting:
DRLs:
Lights on:
High beams:
Thanks,
Do these throw a cel by any chance?
So when you click the lights to "high" either the high beams come on and the low beams go off OR they both stay on? I'm a little confused...could you expand a little?For the golf, everything is the same as well. The only difference is that with the Golf there is a high beam option. The high beams can be the stock halogen bulb, the HID projector, or both. It is a customer decision. Nothing changes from the user end, it is just a wiring modification that I do.
On your Golf, there are separate bulbs for low and high beam. When you pull back the stalk, they both come on(lows are already on, high beams join them).So when you click the lights to "high" either the high beams come on and the low beams go off OR they both stay on? I'm a little confused...could you expand a little?
