Pics of the Dozenspeed Variant Prototype Kit
Hey folks! I thought I should share, so.....
I know Andrew has been partly busy sorting out a couple complications involving intalling these kits on my car. I have been working with him for several months on getting these running in my car, a taxi churning out a consistant 5,500 miles per month that I aim to run to 500k and beyond. So I feel HPFP failure is merely a question of time.
Despite many installations on various models prior to mine, my 2011 6MT (Build 3/11) did not have adequate operating clearence for the availabe kit of the time. Now with Andrew's sheer determination and patience, a specialized, 2micron filter holder designed to use an alternate filter is up and running problem free.
A: The factory fuel filter housing
B: The Pure Flow Kit, installed ~157k miles
C: Special Contain Flow kit filter mount and alternate 2 micro CAT (ipillar) filter, which is narrower to accomodate engine movement installed at 192,011 miles 6-5-14
Below I'm attempting to illustrate the clearence issue. The red arrow designates direction of flex under load, and the green space shows the aquired range for movement from the new thinner filter. The original filter had only 1 mm of clearence at best, so even a slight load would cause that alt bracket edge to crash into the filter body.
From the top you can see the CAT filter is flush with the holder. A mm or two on either side with a curvature made the difference in the clearence needed. We tried with both filters right against the headlamp housing. The CAT filter is longer and that required unclipping the A/C line from the body and giving a it fair tweaking to clear there. Andrew had to send me a second, remachined filter holder to fit the alternate CAT filter in order to accomodate my car. That's a bit dedicated to the project I'd say.
Now everything is field tested and functioning for 750 miles, but we'll hopefully be able to tally up thousands of "test" miles on this system very soon.
My sincere gratitude goes to oilhammer who volunteered his expertise and installation services at no charge in order to learn about this mod first hand. Keep THAT in mind if you are looking for an install and can make it to St. Louis. (Sorry, I don't know what he'd charge for labor.)
Bonus pics:
