Old March 14th, 2017, 18:50   #1
Nate660
Default Blow by 2001 alh
Engine I have had blowby how much is acceptable? The oil cap bounces around but doesn't blow it off. From my understanding these engines will have blowby?
Nate660 is offline   Reply With Quote
Old March 14th, 2017, 18:52   #2
oilhammer's Avatar
Fuel Economy: fantastic
All engines have blowby. Are you having some problem that is prompting you to look for something that likely is not a problem?
www.cardocautomotive.com
Old March 14th, 2017, 19:10   #3
Nate660
Nope good fuel mileage running fine. Just noticed it the other day while looking over the engine bay with it running. I just want to know how much is ok because I travel quiet frequently and don't want to be left sitting do to low compression
Old March 14th, 2017, 19:16   #4
UhOh
UhOh's Avatar
If the oil cap doesn't seal well get a new one: they're cheap.
If you're worried about the engine's compression get a compression test done. Face your fears head-on!
UhOh is online now   Reply With Quote
Old March 14th, 2017, 19:22   #5
oilhammer's Avatar
It sounds like there is nothing wrong with your engine. I'd not give it a second thought. If it runs good, no excessive smoke or strange noises or hard starting, no bad oil consumption, then motor on.
Old March 14th, 2017, 19:31   #6
Nate660
No oil consumption at all I'm at 4k miles and it's still full on the stick. Wide open throttle no smoke just alittle black at first which is normal with my karma tune. Love this little motor to death. I have a lifted 2006 mega cab cummins and it just sits because I like this car to much lol
Old March 15th, 2017, 08:05   #7
Powder Hound
Powder Hound's Avatar
Fuel Economy: pretty freakin' good.
The engine will seem as though there is excessive blow by, but this is more a result of the high compression than anything else. Some people think it has to do with the vacuum pump exhausting into the valve cover plenum, but the volume from that pump is negligible.
What is the mileage doing? If it drives well, isn't smoking, gets proper mileage, then no worries.
Excessive blow by would result in oil leaking like crazy from blown out seals because the CCV would not be able to handle the volume of gasses.
Seriously, you have no worries.
Drive on!
Cheers,
PH
Thinking outside the box is difficult for some. They're afraid they'll fall off the edge of the box and be lost to oblivion.
Powder Hound is offline   Reply With Quote
Old March 15th, 2017, 08:41   #8
AndyBees
AndyBees's Avatar
Take the advice of Oilhammer and Powder Hound ......
Problematic blow-by with high miles was a thingy with the 1.6 VW engines (and 1.5). I took the assumption that as long as it had oil in it and would start, no worries.
'84 Vanagon '02 ALH TDI engine(32 to 35+ MPGs consistently) Malone Stage 1 tune. Road trip to Nova Scotia 2013. Road trip to Alaska summer 2014 & 2016, 11k & 12k miles. 80k miles on install, Jetta Cluster odometer currently at 209k miles.
AndyBees is offline   Reply With Quote
Old March 18th, 2017, 07:14   #9
jimbote
jimbote's Avatar
vacuum pump exhaust ... if you need convincing run the engine with the vacuum pump nipple sealed off, then with it fully open ... the amount of volume that little pump puts out is far from negligible but quite astounding
jimbote is online now   Reply With Quote
Old March 20th, 2017, 10:07   #10
compu_85
Gadget Guy
compu_85's Avatar
Ya that's a good point about the vacuum pump emptying into the head.
The general rule is that if the blowby just makes the loose cap dance around it's fine. If the cap is blown off the valve cover, there's too much.
-J
Present:
2013 Fiat 500e. 18,000 miles. Almost 100 miles per charge!
2012 Passat SE TDI DSG. 112,000 miles. Factory Alarm, LED tails, Memory Seat, HIDs 38/48 MPG. Buy it from us!
2004 Touareg V10 TDI. 165,000 miles.
99.5 Jetta "GLX" TDI. 310,000 miles. Half way there!!! Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG.
1991 Mercedes 350SDL 230,000 miles, 70,000 on engine. 18/27 MPG.
Past:
1988 Audi 5000S Quattro, 1992 Jetta ECOdiesel, 1991 Jetta ECOdiesel.
Check out the official TDIClub Chat Room!
Originally Posted by BRUSSELS BELGIAN View Post
Maybe I should pay MYSELF to do bad work on my car!
compu_85 is offline   Reply With Quote
Old March 20th, 2017, 10:19   #11
KLXD
There should be no flow from the vacuum pump unless you have a vacuum leak. It is capable of pumping a lot of volume but it shouldn't be doing it.
Except when it is called on to actuate something like the TC. Then there will be a momentary flow.
Saying no to gas for 25 years:
Current: ’02 Jetta, Auto; ’98 Jetta, 5 Spd; ’98 Dodge, 5 Spd, SB, 4x4; ’84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): ’85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: ’85 Mitsubishi PU, 4D55T; ’81 Rabbit, 1.6; ’80 Dasher, 1.5; ’79 Rabbit, 1.5
KLXD is offline   Reply With Quote
Old March 20th, 2017, 11:19   #12
oilhammer's Avatar
Really? Isn't the N75 and N18 "open" from the source (vacuum pump) side to the exhaust (air cleaner) side during much of its normal operation? The EGR and VNT are not self-venting, so that vacuum needs to go somewhere, which means if it is constantly venting some vacuum, then it has to constantly be producing some vacuum, and that is going to be pushed into the crankcase. Obviously, this is a very small amount (volume) and the engine is designed to accommodate this. Essentially a tiny bit of filtered air (air cleaner post filter) being pushed into the crankcase in some manner most of the time, and being "lost" in the normal crankcase pressure scavenging that occurs as the inlet air is pulled past the PCV right where the heater sits.
At least, that is what I remember from school. If the N75 was just allowing all the vacuum it has available all the time then the actuator would just stay pulled down all the time the engine is running. Same for the EGR solenoid.
Old March 20th, 2017, 12:53   #13
AndyBees
AndyBees's Avatar
FWIW, I have a Vacuum Gauge on the "vacuum system" on my ALH in the Vanagon. When the engine is running, it holds about 23 inches (depending on elevation). The amount doesn't change when I accelerate. I assume the pump is strong enough to keep the vacuum about the same at all times, with one exception. When I hit the brake pedal, the vacuum gauge will dip down and recover almost immediately.
Interestingly, when I shut-down the engine, vacuum drops almost immediately. So, either I have a leak somewhere or the check valve doesn't operate properly. I do have a reserve tank and an individual filter for the system.
Old March 20th, 2017, 17:04   #14
Dieselmonkey02
TDI(s): 02 jetta
Fuel Economy: 48-50 avg. 44 lowest 51.5 highest
One other thing is that the pistons sweep the same volume going down as they do going up. So the will move some air around.
Dieselmonkey02 is offline   Reply With Quote
Old March 20th, 2017, 17:29   #15
Nate660
Well can someone post a video of an engine that they think is healthy so I can get an idea of what I have. Or I guess I could post a video of my engine also
2001 ALH into 2001 Ford Ranger Edge Hasenwerk TDI Conversions 102 April 27th, 2017 09:20
2001 alh egr commonrailkid04 Private TDI Items for Sale/Wanted 0 March 13th, 2012 08:03
ALH TDI blow-by test? TDI_NC TDI 101 2 February 3rd, 2010 23:24
ALH TDI - *New* 3 inch Exhaust - Now mysterious "blow off vlave" noise ?? help please JacobLyons TDI Power Enhancements 23 February 7th, 2008 17:06
How Much Blow By is Good Blow By DeliveryValve TDI 101 6 May 21st, 2007 19:05
Page generated in 0.14977 seconds with 13 queries
[Output: 129.00 Kb. compressed to 107.60 Kb. by saving 21.39 Kb. (16.58%)]
