mikerancourt
UPDATE 6/3/16: SEE POST #56 for the solution.
Since it's started getting colder, my glow plug light doesn't come on when I turn the key (doesn't even flash the 1/2 second). However, the car starts up okay (the colder it is, the more cranking it takes, but never more than a few seconds) after the car starts and runs for a while, I can shut it off; then, when I turn the key again (engine still warm), the glow plug light flashes as it normally should. Today, it's about 50 degrees, and when I went out, I turned the key on and off about ten times to see if the light would ever come on, but it didn't, so I cranked it, and the car started almost immediately. I let it run for only a few seconds, shut it off, turned the key, and the light flashed on.
I have the following codes:
- 01117
- 00626
- I used to get 00525, but not since I got the new Relay 109
I've replaced the following:
- Relay 109 in October
- Relay 180 in June
- 50A fuse in June
I've tested the following:
- Resistance for all four GPs is the same, around 1.0
- Unplugging the coolant temp sensor causes no change
- The GP light bulb on the instrument cluster is good
- I can't test the voltage at the harness - the Glow Plug 101 tutorial doesn't account for the light not coming on, so testing this will only tell me the obvious: there's no voltage when the light doesn't come on.
I really tried and tried to find the solution to this without starting the millionth new thread on glow plugs, but I just can't figure it out (see also http://forums.tdiclub.com/showpost.php?p=3575669&postcount=1270 and http://forums.tdiclub.com/showpost.php?p=3594454&postcount=1289
for my posts on the Glow Plug 101 thread, which unfortunately does not seem to contain my solution)
- 01117
- 00626
- Relay 180 in June
- 50A fuse in June
