Helping out a friend with an EPB fault (2007 B6 wagon). VCDS reports the following:
Running through the diagnostic (from Ross-Tech), he can hear the motor moving, but it fails the function test, reporting "closed" (which makes sense, as the dash light is on, and the bing is binging - except that the brake is clearly not on and the car is driveable).
I'm just wondering if we could jumper the right side connector to the left side motor, to confirm a failed motor, and not some point in the wiring harness or switch. It's my understanding that the motor is "symmetric" (not specific to left/right), but not sure if using a jumper to get to the other side of the car is going to mess up the voltage on the diagnostics.
This car is a bit of a lemon, frankly, reporting near-constant intermittent electrical gremlins - here's a sample that I cleared at last scan (all with different freeze frame dates):
Plan is to unload the car... but need to resolve the EPB issue.
Thanks.
Code:
02433 - Supply Voltage for Right Parking Brake Motor (V283)
012 - Electrical Fault in Circuit - MIL ON
Code:
Address 02: Auto Trans Labels: 09G-927-750.clb
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Address 19: CAN Gateway Labels: 3C0-907-530-V1.clb
01305 - Databus for Infotainment
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
02823 - Requirements for Locking the Steering Column Lock not met
000 - - - Intermittent
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
00896 - Trunk Lock Unit (F256)
008 - Implausible Signal - Intermittent
Thanks.
