Mcgink
- Joined
- Oct 15, 2004
- Location
- South of Boston MA
- TDI
- I-Red,"The Passat formerly known as Harlequin" 97 B4, a non VW GTDI too
Like to see or make a sticky or link about clutch hydraulics diagnosis. Probably could apply to most models. I have a decent understanding of hydraulics/pnuematics.
Assumptions:
This would be specific to the hydraulic end of the clutch (not slippage or chattering)
No hydraulic leaks, if your losing fluid, you have a leak somewhere and are getting air into the system then it is FAIL.
No air in system due to any of the above in the braking/clutch sysytem (B4 brakes and clutch use the same fluid reservior {chime in on other platforms}
Soooo:
I replaced a rear brake line in my B4 and bled the system including the clutch using synthetic brake fluid "meets or exceeds DOT 3&4 standards". Hopefully it meets or exceeds VW standards.
first ~10 mile drive was fine but then the clutch pedal would gradually bleed down to the floor and clutch would engage. I can manually pull the pedal up but the next time I dis-engage the clutch, the pedal will do the same thing.
I bled the clutch again using a piece of tubing fed back to the reservior "brand new fluid" to verify no air in it.
I figure that I need a new clutch master but that it could be the slave as well or both.
My goal is to correctly diagnose which component is FAIL as well as help others from replacing both componets when only one of them is needed. I hope that I haven't "Toofed" "my hydraulic sytem by using synthetic brake fluid "thought it would be an upgrade {like synthetic oil}
Assumptions:
Soooo:
