rtalboys
Hi Newbie here
Purchased back in September of this year. I am new to TDI.
I am having an issue with the inter cooler pipe blowing off and going into (what is described in the forms as limp mode... black smoke out back, no power) first time noticed that the pipe blew off reseated the pipe and everything was back to norm. As soon as I cranked the RPMs past 2500ish .... POP and back to limp mode. I noticed the boost pipe bracket was broken and thought this may in fact be the cause. I fabricated a new bracket to hold this in place because the old connection to the frame was broken as well(metal was broken hanging by a thread snapped off when I moved it) any way I have some photos below and I have purchased the ROSS-tech VCDS cable and installed the software. below are the codes I am getting and some photos of the broken bracket and fabrication of the new/temp bracket.
any help/ideas would be great!
rtalboys
Wednesday,30,October,2019,11:10:18:51072
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
Data version: 20190930 DS308.0
www.Ross-Tech.com
VIN: 3VWCR31C35M401735 License Plate: CLN8610
Mileage: 364740km-226638mi Repair Order: 5
Chassis Type: 1C (1C - VW New Beetle (1998 > 2010))
Scan: 01 02 03 08 15 17 19 25 29 35 37 39 46 54 56 65 75
VIN: 3VWCR31C35M401735 Mileage: 364740km-226638miles
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 038 997 016 M HW: 028 101 181 3
Component: R4 1,9L EDC G000DG 2878
Revision: 12345678 Serial number: VWZ5Z0D5151193
Coding: 0150038
Shop #: WSC 07437 444 85530
VCID: 2809FF9EBEEF6347A17-5160
3 Faults Found:
18628 - Oxygen (Lambda) Sensor B1 S1
P2196 - 000 - Signal too High (Rich)
Freeze Frame:
RPM: 1512 /min
Torque: 0.0 Nm
Speed: 31.0 km/h
(no units): 255.0
Temperature: 54.0°C
Absolute Pres.: 999.6 mbar
Voltage: 1.752 V
Lambda: 0.0 %
16683 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached
Freeze Frame:
RPM: 2142 /min
Torque: 142.0 Nm
Speed: 62.0 km/h
Load: 49.8 %
Voltage: 13.83 V
Bin. Bits: 00001000
Absolute Pres.: 1713.6 mbar
Absolute Pres.: 948.6 mbar
16485 - Mass Air Flow Sensor (G70)
P0101 - 000 - Implausible Signal
Freeze Frame:
RPM: 1449 /min
Torque: 0.0 Nm
Speed: 67.0 km/h
Temperature: 39.6°C
(no units): 100.8
(no units): 0.62
Temperature: 83.7°C
Readiness: 1 1 0 0 0
link to photos
https://photos.app.goo.gl/YLQ8GhCqJiun1tDQ7
rtalboys
www.Ross-Tech.com
Coding: 0150038
3 Faults Found:
Freeze Frame:
RPM: 1512 /min
Torque: 0.0 Nm
Speed: 31.0 km/h
(no units): 255.0
Temperature: 54.0°C
Voltage: 1.752 V
Lambda: 0.0 %
Freeze Frame:
RPM: 2142 /min
Torque: 142.0 Nm
Speed: 62.0 km/h
Load: 49.8 %
Voltage: 13.83 V
Bin. Bits: 00001000
Freeze Frame:
RPM: 1449 /min
Torque: 0.0 Nm
Speed: 67.0 km/h
Temperature: 39.6°C
(no units): 100.8
(no units): 0.62
Temperature: 83.7°C
link to photos
