TDI-JAY
I've been tuned for the last 6,500 miles, for the first time the car tossed a CEL light. I scanned the car & it had 4 hard codes. Torque Difference limit exceeded - intermintent - but for all four cylinders. Looking at the log it looks like different cylinders had it happen more than others & at different mileage. Car still runs great & pulls hard.
Shortly after the car was tuned I was checking the readiness and noticed I had 2 pending codes (forget what cylinders, but 2 of these codes) for this same thing. I cleared them & never scanned the car again, so I don't know how long or if at all these were pending. When I google these codes or look them up with ROSS-TECH it simply says a dirty injector or low compression. Just weird to see it across the board on every cylinder. Could it be an issue with the glow plugs as they monitor cylinder pressure? What would cause this & should I worry? I've gone 100+ miles since clearing all codes and none have returned. Fuel filter was done 2,000 miles ago. Could bad fuel do it? (Light came on 15 minutes after fueling up at a hole in the wall diesel station, I was low & HAD to stop)
P1004 #1
P1005 #2
P1006 #3
P1007 #4
* LOG *
4 Faults Found:
004103 - Torque Difference Cylinder 4
P1007 - 000 - Limit Value Exceeded - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 2
Fault Frequency: 35
Reset counter: 255
Mileage: 171118 km
Time Indication: 0
Date: 2000.00.00
Time: 09:54:55
Freeze Frame:
RPM: 2714 /min
Speed: 92.0 km/h
Load: 72.5 %
Bin. Bits: 00010001
Torque: 396.0 Nm
Bin. Bits: 00000000
Ign. Timing: 18.4 °ATDC
004101 - Torque Difference Cylinder 2
P1005 - 000 - Limit Value Exceeded - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 29
Reset counter: 255
Mileage: 171118 km
Time Indication: 0
Date: 2000.00.00
Time: 09:54:55
Freeze Frame:
RPM: 2714 /min
Speed: 93.0 km/h
Load: 72.5 %
Bin. Bits: 00010001
Torque: 396.0 Nm
Bin. Bits: 00000000
004100 - Torque Difference Cylinder 1
P1004 - 000 - Limit Value Exceeded - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 17
Reset counter: 255
Mileage: 171145 km
Time Indication: 0
Date: 2000.00.00
Time: 10:08:50
Freeze Frame:
RPM: 2346 /min
Speed: 101.0 km/h
Load: 65.9 %
Bin. Bits: 00010001
Torque: 363.0 Nm
Bin. Bits: 00000000
Ign. Timing: 17.1 °ATDC
004102 - Torque Difference Cylinder 3
P1006 - 000 - Limit Value Exceeded - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 17
Reset counter: 255
Mileage: 171145 km
Time Indication: 0
Date: 2000.00.00
Time: 10:08:50
Freeze Frame:
RPM: 2967 /min
Speed: 101.0 km/h
Load: 78.8 %
Bin. Bits: 00010001
Torque: 435.0 Nm
Bin. Bits: 00000010
Ign. Timing: 23.4 °ATDC
Readiness: 1 4 0 0 0
P1004 #1
P1005 #2
P1006 #3
P1007 #4
* LOG *
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 35
Reset counter: 255
Mileage: 171118 km
Time Indication: 0
Date: 2000.00.00
Time: 09:54:55
Freeze Frame:
RPM: 2714 /min
Speed: 92.0 km/h
Load: 72.5 %
Bin. Bits: 00010001
Torque: 396.0 Nm
Bin. Bits: 00000000
Freeze Frame:
Fault Priority: 2
Fault Frequency: 29
Reset counter: 255
Mileage: 171118 km
Time Indication: 0
Date: 2000.00.00
Time: 09:54:55
Freeze Frame:
RPM: 2714 /min
Speed: 93.0 km/h
Load: 72.5 %
Bin. Bits: 00010001
Torque: 396.0 Nm
Bin. Bits: 00000000
Freeze Frame:
Fault Priority: 2
Fault Frequency: 17
Reset counter: 255
Mileage: 171145 km
Time Indication: 0
Date: 2000.00.00
Time: 10:08:50
Freeze Frame:
RPM: 2346 /min
Speed: 101.0 km/h
Load: 65.9 %
Bin. Bits: 00010001
Torque: 363.0 Nm
Bin. Bits: 00000000
Freeze Frame:
Fault Priority: 2
Fault Frequency: 17
Reset counter: 255
Mileage: 171145 km
Time Indication: 0
Date: 2000.00.00
Time: 10:08:50
Freeze Frame:
RPM: 2967 /min
Speed: 101.0 km/h
Load: 78.8 %
Bin. Bits: 00010001
Torque: 435.0 Nm
Bin. Bits: 00000010
