Osito
No noticeable change in running, but my 2002 Jetta (111k) has started giving a CEL. The code is a single P0763 (glowplug/heater #3). After looking up the info on this site, I checked the glow plugs - all at about 0.1 ohm. The harness looks good, and checked out at 12.7 volts across the board. I used DeoxIT in the boots. I checked under battery connection/fuse cover, and read 12.7 volts at each connection. After reassembly, it still throws the same code.
Is there something else to check? Do I remove the "harness" end of the harness and check and DeoxIT? Basically, is there something else to try before replacing the glow plug harness?
