kaellis
I'm having some intermittent voltage issues. Every once in a while, when the engine is cold and I pass 2500 RPM, when the glow plug relay switches on or off, the lights will flicker badly and various fault codes will be triggered (voltage out of range) and the ABS and brake warning lights will come on. When parked and cold, I can start and watch the dome light, and going up through 2500 RPM it will flash brightly (voltage too high), and on the way back down will dim. Multimeter too slow to catch values. When I then shut the car off and leave the key in the ignition, the LCD displays on the dash (odometer) will go out. Oddly, they will come back on while I have the brake pedal depressed, will go out again when I release. When I remove the key from the ignition, everything back to normal, and the alarm sets. Rarely, after this happens, I will hear repeated clicking from under the dash like a relay tripping a couple times a second.
Note also that I see voltage spikes when I hit the defrost or even turn signals, but it isn't bad enough to trigger fault codes.
I replaced the voltage regulator. Brushes had 8mm left on them, within 1mm of spec. Didn't help though. I removed and cleaned the negative battery cable. No help. Relay 109 has been replaced. I'm thinking the LCD and brake pedal weirdness is just a result of the voltage drop.
Any ideas here? In absence of any suggestions for diagnosing, I'm thinking replace the glow plug relay. The problem is getting progressively worse.
2000 Jetta TDI, 135k miles.
