We'll I stumbled upon this deal.
99 tdi alh 5 speed with 247000 on it. Owner said the battery light came on and was putting out 18v. Sat for 2 months and didn't start.
Had the timing belt done at 230000 and a whole new turbo at 225000, lol.
I stepped in and bought it for $0.
Done so far:
Battery
Battery mount
Alternator (fixed over voltage problem)
Oil change
Fuel filter change
Air filter
Tranny fluid change
Tire rotate
All new pads and rotors around
Daytime running light delete
3m headlight polish
Reinstalled the torn off bottom engine cover
Power steering flush with cfh11s, nasty!!!
Thermostat
Egr delete
Muffler delete
Stage 2 Malone tune
straight piped no cat
HVAC fan fix (JB weld) - ended up buying a whole new assembly. Not because the JB didnt last but just to be safe with northern MN winters.
new HD radio tuner with antenna and base
snow filter cleaning
new glow plug harness
new glow plugs
new inner and outer tie rods (moog)
new front sway bar links (moog)
new lower control arms with ball joints (moog)
all new silicone vacuum hoses in engine bay
rebuild CV axles
new moog strut assemblies
new AA rodriguez front hub assemblies with bearings and WSS (ended up having right front wheel speed sensor go bad, replaced with $70 ID parts).
New front brake lines
New front brake pads
New front brake rotors (bosch quiet cast)
New tires (cooper Cs5)
Alignment
Midwest motorworks 300K overhaul (includes timing belt change, camshaft, oil pump chain/guide, etc lots of work was done to the engine to get it up to snuff for another 300k)
single mass flywheel and new clutch pack (Stage 2) and crank seal while back there.
turbo boost gauge
EGT gauge
Battery voltage gauge
Power plus 520 nozzles.
Updated Bosch MAF sensor
New Coolant overflow tank/cap, upper and lower radiator hoses, oil cooler hoses
Mud flaps
updated cup holder
rear springs and mounts
rear shocks, bump stops and hardware
rear hub assemblies and hardware
rear stub axles and hardware
rear ABS sensors
rear brake lines from ABS module to calipers
rear pads
rear rotors
rear calipers
Sand blasted and POR 15 rear axle
rear parking brake lines, hangers/mounts and stainless tubes
rear axle bushings (Cupra R) and hardware
New front fenders
Fixed rust on rocker panels
ECS Tuning smoked side indicator lights
New front pads and rotors.
windows tinted.
So I've put on about 38,000 miles and love this little thing. Getting consistent in the 53-54 mpg! Mileage update 300,000 miles
Now things on the list
Fix my drivers rear window! won't go up or down with driver controls
Been fun so far, best part is I get paid for the miles I put on this car for work. Since I have started driving this car, I keep a spreadsheet active of the money received from work and all the money I have into and to this date I am still up over 2k!!!
Done so far:
Battery
Battery mount
Oil change
Fuel filter change
Air filter
Tranny fluid change
Tire rotate
3m headlight polish
Thermostat
Egr delete
Muffler delete
Stage 2 Malone tune
new glow plugs
rebuild CV axles
Alignment
turbo boost gauge
EGT gauge
Mud flaps
updated cup holder
rear ABS sensors
rear pads
rear rotors
rear calipers
New front fenders
windows tinted.
