cjharris02892
- Joined
- May 4, 2004
- Location
- West Kingston, RI 02892
- TDI
- 2000 New Beetle, 2000 Golf and 2005 Jetta MKIV w/BEW
2000 New Beetle with 211,000 miles. I've tracked down 13 CELs for a friend and she is left with 1 problem which I can't find any information on.
The last CEL is an implausible engine speed problem and in her words "really bad gas mileage" (no she doesn't put gas in the car).
I couldn't seem to track it down until I drove the car myself and found out the both the tachometer and gas gauge intermittently don't reset themselves to 0 when you turn the car off. When the tach doesn't reset, it throws the implausible CEL on the next start cycle. When the gas gauge doesn't reset correctly, the "really bad gas mileage" happens.
If I turn the car ignition on and off without starting the engine a few times the gauges eventually will reset a little each on/off cycle until they reach zero and all is fine for a while, then it happens again. No real pattern to when, just random.
Any ideas?
Any ideas?
