Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > Other VW Group TD(I)s
Other VW Group TD(I)s To keep with the theme of VW Diesels, this message area is for discussion of other VW Group Diesels. Yes, TD's are also welcome.
Old January 12th, 2008, 13:55   #1
meldrew
Fuel Economy: 54mpg
Default Skoda Fabia 1.9TDI (PD) failure of injector cable tree in cylider head
My 2002 Skoda Fabia 1.9TDI (PD type injection) developed a severe misfire. Fault code given is 18075 (No 2 cylinder) and indicates that I should replace the 'cable tree' in the cylinder head. Whilst I could find no fault using a precison ohm meter on this 'cable tree' I have replaced it and the car has been fine for the last 200 miles. The VW dealer had 12 in stock so they must be a regular item! I understand that the ECU effectively sends a signal out prior to injection to check the integrity of the whole circuit including injector, if not ok then it 'blocks' the firing signal, but it must be very sensitive??
Meldrew
meldrew is offline   Reply With Quote
Page generated in 0.13357 seconds with 10 queries
[Output: 42.93 Kb. compressed to 40.26 Kb. by saving 2.67 Kb. (6.22%)]
