Üdv.. köszönöm.. szerintem beszéltem velük de ök csak új turbot akartak adni..átalakításhoz alkatrészt nem adnak.. ettől függetlenül jó dolgok vannak náluk,de nekem sajnos drága..meg öszintén szólva szeretem magamnak csinálgatni,,Igen, természetesen lehetséges. Az AVD Turbo biztosan tud segíteni ezügyben.
Thanks..Gtb 2056vk is a lot more reliable than the gtb2260vklr. You can also put vk core into vklr housing and the same principles apply but you get better vnt system compared with vklr and better AR on compressor side.
Rub, you got 460hp from the new style turbine, what kind of boost/emp ratio you had?51mm wheels works just fine without vanes touching it.
with good compressor/turbine clearance 2.65 bar boost and 3.2 bar EMP at 4000Rub, you got 460hp from the new style turbine, what kind of boost/emp ratio you had?
Thanks.. that's nice performance.. Amg turbine Wheel turbo?Audi a6 204/245 base
thanks .. I looked really much better TD05.. than amg ..no. TD05 modified by Oleg from spain
I would assume that was just on one bank? The volume needs for that engine are much greater.Well, i tested gtb1749vzk (the one with the speedsensor) on the q7. At 2 bar boost they were running 220k rpm...
Basically made less power then at 1.8 bar.
The only thing I would add to my wish list is highlighted.GTD2263VZR - prototype
TW : Exducer 44.5m / Inducer 50mm - 9 baldes
CW : Inducer 45mm / Exducer 63mm/ Extendet 66.5mm - 10blades
Yes is TIthat compressor is very dark and yellow colored for aluminum
Ti?
I guess my other wish is that GTB3576KLNRV would not be so expensive and hard to find
50/65mm should do just fineSince we are talking about 2260's
Can someone confirm that the 2nd generator 3.0 TDi engines have the GTB2260 turbo in them? The SSP 495 states it on page 17, but I just wanted to make sure.
This would be a NAR Touareg rated at 240hp from the factory.
If this is true, what would you guys recommend as a replacement compressor wheel?
No problem if the compressor housing needs machined out.
Would like to get around 300-325whp reliably, possible?
Thank you sir!50/65mm should do just fine
I don't think you will notice much of a difference in spool especially after remapThank you sir!
How laggy will this be with the V6 3.0?
