bioburner
I thought it might be helpful to start a list of the use of what seems to be a fairly comprehensive warranty that accompanies the emissions repair. I have a higher mileage 3.0 and the warranty made the repair worth the gamble.
Fault code P245B00- EGR cooler bypass performance. Replaced the EGR cooler 059131515FP. Required removal of intake manifold.
Fault code P20FE00 -Reducing agent performance. Adblue filter housing loose, pump damaged. Replaced pump 4L0131899M and filter housing.
Just those two were a couple grand in parts, not sure what the labor was. I think the warranty will be very beneficial to those with higher mileage vehicles whose emissions components, as well as quite a bit of other parts, might be at the end of their useful life.
