It's surprising when you drive a car that Jeff has tuned for a while and then go back to a stock one. The way his tunes deliver power feels like factory, only more.
..2011 jetta 6mt..70,000 miles on the ticker...owned around 7 years..never got more than 43 mpg before fix..after fix lucky if 41..anyway got the kerma Q loader tune a few months ago ( lot more torque/pick-up,tires break loose way more than before!)..first long trip since tune (1400 miles round trip around 75-78 mph,fla. turnpike..Athens Ga. to Jupiter Fla.....done many times).. few hundred miles into it used around 1/4 tank, I went around 300 miles.. huh?..double checked..then went to 500 miles ( a little less than 1/2 tank!) mfd showing 55.6 mpg..yea right LOL."somethings not right". and filled it up 10,5 gallons ( always fill to the top)..hand calculated it.. got 53 mpg!..this can't be right?..total mileage same as scan gaugeII ( speedo/odo correct)....still can't believe it..so went thru part of another tank (580 miles on the way back) checked again.. 52.7 mpg..WOW!. Up from 41 or so to 53 hwy..Hard to believe..but it is what it isYep. Got a Kerma tune about 8k miles ago on my gen 1 cr tdi Aka no ad blue. Very well balanced and it still follows regen.
