Jerz
- Joined
- Nov 19, 2013
- Location
- Alberta, Canada
- TDI
- 05 Passat Wagon GLS TDi 180hp, 5 speed swap; 05 Passat Wagon BEW swap (wife's, traded for OM606 Merc soon to be STD); 05 Mazda B3000 2.0mTDi swap (sold); Boxster S TDi swap (under construction)
I have started a new project. – Mazda B3000 (Ranger) to 2.0 TDi conversion.
I have lots of left over parts from B5 Passats I worked on and got a nice shape/dead engine truck for cheap.
This will be a budget build. I couldn’t find an adapter, so I carved one from 3/8 steel plate. The Mazda flywheel was machined for the TDi crank nose.
I am planning to run original clutch, TDi starter, and probably compounded turbos.
I am debating going M-TDi route for simplicity and cost. Have most parts to put a system together, but I also have BHW harness, computer, and dash, if decide to go that route.
I need an opinion from M-TDi guys on that. I have a tuned Passat and love the way it drives. How well does m-TDi work for you guys?
