pietch
- Joined
- Apr 7, 2006
What is the mod known as, called, refered to as?
http://cgi.ebay.co.uk/TDI-Diesel-Tuning-Box-PD-VW-AUDI-SEAT-SKODA-FORD-38BHP_W0QQitemZ300246766497QQcmdZViewItem?hash=item300246766497&_trkparms=72%3A12%7C39%3A1%7C66%3A2%7C65%3A12&_trksid=p3286.c0.m14.l1308
My one has an adjustable resistor, I have tested it with a multimeter and get a resistance of 152>253 - the higher the resistance the more power the engine makes. This is probably the best mod on my car, it causes no CEL lights and really helps 800-2000rpm flat spots... if I could choose any mod, digital box, proper remap or this I would choose this, it is the one that actually makes the car a better drive, not faster, just better, especially regarding the clutch/ gas pedal relationship.
I also have another one which is faulty, the resistor is never stable and changes between 150>450! With this device the car is super 'rough' but flys!!
Info I found on these devices:
"These devices are just a single resistor across the terminals on the fuel temperature transducer wires will cause the ECU to trip in the 'winter fuel settings'. The ECU sees the fuel as being at it's 'maximum cold' state, hence increases injector duration, changes timing etc to improve engine conditions for the fuel it expects is now much denser. If you trip that function you get more fuel from the injection system and more power. It works, but there are issues. The mod is not controllable in any way, the extra fuel is only issued at lower rpm – nothing over 3250 rpm."
Do these devices only work until 3250rpm?
Do they trip the cold fuel maps?
Can they be used with a remap?
I am using one with a remap no problems for 20k+.
Feedback appreciated!
