Old January 5th, 2018, 08:04   #1
jackjtr
Default GT15 Turbine Housing Stuck
I'm rebuilding my GT15 off of my 175k mile Passat, and I can't seem to get the turbine housing off of the center cartridge. I've scoured Google, and all I can find is "hit it with a hammer" and "soak it in penetrant" which I have been doing for days. I tried heat and penetrant. Still nothing. It's just so small.
It's almost as if the housing has rust-welded itself to the cartridge. Should I go buy a wire wheel for my Dremel and do some extreme cleaning around where the two pieces meet? Find someone with an oxy torch?
I know a lot of you think the GT15 is a throw-away turbo, but I can't justify spending the money on a K03/04 if I can just rebuild the stock turbo. It's destined for my EuroVan.
jackjtr is online now   Reply With Quote
Old January 5th, 2018, 09:53   #2
Mongler98
1:1 ATF and Acetone. Dont use plastic bottle. The best rust eater out there is sold from tractor supply. I dont recall what its called but its in a while can with black lettering, its got sculls and crossbones warning on it, its a heavy acid for rust resolving in the field on old equipment. DO NOT GET IN YOUR EYES, wear safety glasses 100% or you can go blind from this stuff.
If all your bolts are off the turbo it should come out. Soak it overnight in a bath of 1:1 acetone and AFT mix. Then tap it with a hammer. I HIGHLY suggest you use a dead blow hammer mallet. they are cheep at harbor freight.
Choosing a turbine housing bassman5066 TDI Power Enhancements 2 September 19th, 2013 10:26
WTB gt2052 turbine housing Shane47 Private TDI Items for Sale/Wanted 0 June 16th, 2013 06:03
where to obtain GT15 0.47A/R turbine housing? Russ220 TDI Power Enhancements 2 July 21st, 2010 02:26
VNT15 turbine housing HO'OLAKO TDI Power Enhancements 0 April 1st, 2007 18:09
Need a different T3 Turbine housing...trade or buy Cosmobug Private TDI Items for Sale/Wanted 0 December 7th, 2004 08:14
Page generated in 0.10875 seconds with 11 queries
[Output: 52.19 Kb. compressed to 48.29 Kb. by saving 3.90 Kb. (7.47%)]
