Old December 22nd, 2013, 21:39   #1
speedbump71
Default Liquimoly Diesel Intake Cleaner
Anybody ever used this stuff? I cleaned my intake the hard way last week, but I wonder if something like this every once in a while might help prevent any build up.
http://liquimoly-servicepartner.com/...ystem-cleaner/
speedbump71 is offline   Reply With Quote
Old December 22nd, 2013, 21:52   #2
8v-of-fury
Guest
Dang, looks super easy.
I'd give it a go if I didn't just do it the "hard way" too haha.
Old December 23rd, 2013, 08:10   #3
curtludwig
Fuel Economy: '98 - 47-53mpg, '05 - 44-48mpg
If it seems too good to be true, it probably is. Remember they're spraying that into the intake. Where do you think the crud is going?
My blog about everything: http://curtsotherblog.blogspot.com/
curtludwig is offline   Reply With Quote
Old December 23rd, 2013, 08:24   #4
8v-of-fury
Guest
Right out the exhaust? lol
That stuff probably turns the soot in to a chemical "fuel" burnable by the engine.
Old December 23rd, 2013, 10:01   #5
KLXD
I figger all that crap just gets washed further down the pipe and settles out.
"Look customer, nice clean EGR valve! That'll be $200."
Current: 02 Jetta, Auto; 98 Jetta, 5 Spd; 98 Dodge, 5 Spd, SB, 4x4; 84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): 85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: 85 Mitsubishi PU, 4D55T; 81 Rabbit, 1.6; 80 Dasher, 1.5; 79 Rabbit, 1.5
Old December 23rd, 2013, 11:10   #6
8v-of-fury
Guest
The way I see it, people have been doing that with "Seafoam" for a long long time. This is just a diesel safe version of that, one which isn't so much of a fuel for runaways maybe??
Old December 23rd, 2013, 12:48   #7
curtludwig
As long as all the pieces are broken completely into a slurry theres a possibility they could move through the system completely without hurting the car. If chunks of crud get loose and get into cylinders and pounded between the piston and valves you'll wish you hadn't...
Old December 23rd, 2013, 13:05   #8
8v-of-fury
Guest
If the liquid in the cylinder doesn't provide a situation for bent rods or valves, I don't see the mushy soot to be an issue either?
That stuff in the intake is pretty soft after all.
Old December 23rd, 2013, 14:20   #9
curtludwig
Cripes you're right I didn't even think about liquid in the cylinder pounding holes in the pistons...
"Magic beans"
Old December 23rd, 2013, 16:45   #10
8v-of-fury
Guest
I don't think it is as huge an issue as you are making it out to be, clearly water injection setups aren't out there destroying anything.
LoL.
Old December 23rd, 2013, 20:50   #11
Digital Corpus
Digital Corpus's Avatar
Given that the solvent can rev up the engine, it is a fuel that some diesel engine can run on. I wouldn't worry about piston pitting.
Turbo Upgrade | Engine Rebuild | Photos | Lighting Mods
Dyno Graphs | 4-Bar sensor | GTB1756VK | Hot-swappable 2.5" down pipe | R520's | DC Stg IV Clutch w/ 14 lb flywheel | PD130 intake manifold
Digital Corpus is online now   Reply With Quote
Old December 23rd, 2013, 21:01   #12
john.jackson9213
TDI(s): 1996 B4V
Mouse Milk, nothing more.
JJ
1996 B4V, Hella E-Codes, GLX leather, EuroTuning.cz 02A 6 speed conversion w/.71 5th and .588 6th gear, A4 shift linkage by Matt-98AHU. 11 mm pump by Oldpoopie. Now, GTC1549VZ turbo by Whitbread. TDtuning, 24 lbs. boost, 162 hp, 285 lb/ft tq. Smoke Free (9/18/15). Koni Yellows and Big Brake 5 lug conversion.
john.jackson9213 is offline   Reply With Quote
Old December 24th, 2013, 04:42   #13
Abacus
That helpful B4 guy
Abacus's Avatar
I'll send this over, install it and try the 'cleaner' on your car, then let us know how it goes.
'97 B4: 453,000 miles Malone 3, K03/04 Hybrid Turbo, PP520's, Stage 2 cam, SBC3, ARP studs, Westach EGT/Boost, Koni Reds/Yellows, 2 1/4" exhaust, 2.5" Cat, no mufflers or EGR, Evo plate,
BUG*PWR 2013 Award Winner
Old December 24th, 2013, 04:53   #14
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
The BG guys were here a few years back, and saw that we had several TDIs in the shop. They mentioned a system they had that was pretty much identical to this by the sound of it, that hooks into their gasser decarb system (which I own, and it works quite well).
I asked him about diesel runaway, hydrolocking, etc. and they answered with "No, I don't think you have to worry about any of that". So I said "OK, send us the setup with enough product to do a couple cars, and we'll try it out."
A week went buy, never heard anything. I was genuinely interested, as BG seems to make good stuff, and I have had good luck with their gasser intake cleaner system over the years. I eventually called them, and they said "Oh, sorry, we can't sell any more, we suspended the product, too many techs were blowing engines up".
So, while I think the idea of this sounds great, in practice it probably is a little too sketchy to work in a manner that doesn't offer too much possibility of catastrophe. Granted, you could tooef a gasser, too, if you were not careful, but that is MUCH less likely to happen.
I think the only way for this to work would be to take it slow... VERY slow. And it may end up taking SO long and using SO much product (and fuel) that it would be just as easy to yank the EGR/intake off and manually clean it. At least on the TDIs. Luckily, with ULSD the gunking is very much reduced. But in light of that, it makes me wonder if a system like this would be more useful for periodic cleaning since the "clogging shut" issues have vanished.
I've since talked to the BG folks again, and they have a newer system in place that is supposed to be safer. I have not decided yet if I want to try it out.
http://www.bgprod.com/catalog/diesel...#bg-product-13
oilhammer
www.cardocautomotive.com
Old December 24th, 2013, 05:41   #15
Votblindub
Votblindub's Avatar
When I posted about it, the responses were essentially saying that it's a good maintenance product AFTER cleaning the intake out. It makes sense to me to be cautious of dislodging pieces falling into the combustion chamber or jamming a valve open. Obviously, if you just dump out a cup of it in the intake, you could hyrdolock the motor, but I might pick up a can to use on the residue on the intake only after it's off the motor, so there's no risk involved. If you guys want to, let me know, I can find some and make a video so we can see what comes out of an intake that's not been cleaned. It might turn all that oily sooty goodness into fluid or make it fall out in chunks. I plan to use it as a maintenance product though. It's quick and easy enough to squirt some in the intake past the MAF or just remove that rubber elbow in front of my EGR. I have a MK4, but I don't think it makes a difference for the purposes of just seeing HOW it affects the gunk in the intake and to see what comes out of it.
Sprint 520 Nozzles, 2.5 inch catless mufflerless BuzzKen exhaust, Malone stage 3 chip, 01M, Frostheater Full details
Full details
FB page for wagon lovers I have VAGCOM/VCDS
Votblindub is offline   Reply With Quote
Lubromoly proline diesel purge vs Liquimoly diesel purge D-Cell_Mekanick Fuels & Lubricants 8 April 3rd, 2014 22:44
Diesel Intake Cleaner bobgolf2004 Fuels & Lubricants 17 March 20th, 2014 08:09
LiquiMoly Diesel Purge JungleMan Ontario 3 November 13th, 2007 13:33
Liquimoly Diesel High-Tech Kier Fuels & Lubricants 5 July 10th, 2006 17:54
Oven Cleaner for the intake?? Hamsterdiesel VW MKIV-A4 TDIs (VE and PD) 15 October 2nd, 2002 07:58
Page generated in 0.16891 seconds with 11 queries
[Output: 120.82 Kb. compressed to 99.93 Kb. by saving 20.89 Kb. (17.29%)]
