JTBioTDI
*SOLD* 2005 Black Golf TDI GLS Manual 5-speed in Washington, D.C.
**********SOLD***********
Hi there,
I'm a new member here, but have previously browsed the forums/articles on-and-off since ~2006. You guys are awesome, and I really appreciate all the good info and solid vibes you've put out over the years. I don't know much about cars, but I have loved learning what I can.
I am selling my 2005 Golf TDI GLS 5-speed. My Baltimore Biodiesel friend Paul Powichroski, who is an enthusiast member of TDIclub.com, suggested I post here to optimize the chances of the car going to a good home. It has a good deal of sentimental value to me, and I want it go to someone who will appreciate and makes good use of it. It doesn't have any mods or anything exciting, just some solid miles. I know it will need more love as it continues to age gracefully (see list of repairs/maintenance below), and I'm moving to a new phase of my life where I will need to put those resources elsewhere.
The color is black with a gray cloth interior. (Please click on the thumbnail below to see the photos, in my member photo album.) It's got 131,182 miles on it. I purchased it used from a dealer in 2010, and to my knowledge I am the second owner. I have most of the maintenance records, which I would be happy to share upon request. The major points are listed below:
I live in Washington, DC and would be willing to meet you for a test drive within reason.
-Joy T. Rubin Shen
Hi there,
- Fuel: 99% ASTM certified biodiesel, except 50/50 blend the past three winters (the car and myself lived in coastal California from 2010-2015, where it never gets cold enough for the fuel to gel, before we moved to DC) and 80%+ petroleum diesel during long road trips.
- Oil changes: Avg. every 5-8,000 miles, full synthetic 5W-40
- Fuel filter changes: Twice a year
- Transmission/ transaxle overhaul and clutch replaced 2012
- Alternator pulley replaced 2014
- Replaced: Rear shocks+mounts, right fender liner, timing belt, serpentine belt, water pump, thermostat, left front outer axle boot, auxiliary radiator fan, intake boost hose, both front suspension lower control arms, battery - 2015
- Hood and rear bumper body damaged in vehicular accident - repaired/replaced 2016.
- Replaced: Fuel pump, brake booster, 2 tires - 2016
- Replaced 2 tires, both rear brake pads and rotors, air filter, cabin pollen filter; cabin temperature control lever repaired, driver side safety mirror casing/mirror/wiring replaced - 2017
- Replaced engine fuel hoses, engine oil and cooler hoses, EGR coolant hose, upper radiator hose, coolant hose assembly, left inner tie rod end, vacuum tank - 2018
- External:
- Left wheel liner torn
- No belly pan - left lower and center engine covers missing, right lower engine cover damaged
- Left rear door exterior handle blank/cap missing (current covered with a square of black duct tape)
- Headlight lenses getting opaque
- Radio antenna sheathing worn off at base
- Scratch on right rear passenger door
- Slight dent on front driver’s side door / body quarter panel
- Minor scratches on bumper
- Mechanical
- Rear brake light bulb holders & wiring connectors have corrosion present
- Needs front left camber caster kit & rear right camber shim
- Interior/Cabin
- No front passenger visor
- Glove box handle broken off, glove box latch mechanism broken, glove box door wedged shut with tissue
- Cabin power outlet cover not attached
- Armrest latch broken & staining on armrest top
- Upholstery stains on rear seats
- Rear cabin ceiling fabric loose at back edge, front cabin ceiling fabric patch glued
- Trunk interior floor has had biodiesel and petroleum diesel spilled on it
-Joy T. Rubin Shen
