Got a Passat TDI with the automatic/steptronic gearbox. When driving 50-60 mph (90 km/h) the rpm goes "up and down" in intervalls.. As if the gearbox was trying to tedt what gear it is supposed to use.. If I decrease the throttle it stops and simple decreases the speed, as it should.
Is this something its supposed to do? Its about 100 rpm's difference.. its more common under 2000 rpm then over..
Ideas?
Ideas?
